Identifying a cap
  • TBob2007
    • Jul 2007
    Identifying a cap
    Im trying to work out what type of cap i need for an Intel SE7520JR2.
    The info on the side of the cap is
    614
    SEPC
    560
    4
    They are solid topped caps (Purple and Silver color) and the motherboard is missing one. Any help would be much appreciated.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Identifying a cap
    sanyo polymer cap 560uf 4v
    is it torn off or the spot not stuffed when the board was made?
    • TBob2007
      • Jul 2007
      Its been ripped off. No damage to the board though. So ill need to de-solder and put a new one in
      Any recommendations on where to get a replacement?
      I live in Reno,NV so a local store would be great
        Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook 3 Specification for Upgrade or Repair
        This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...
        09-07-2024, 12:40 AM
      • madscientist750
        Replacing electrolytic caps by solid caps on old motherboards
        by madscientist750
        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
        10-19-2025, 06:10 AM
      • AustinCER
        Need Help Identifying this LCD FPC for Dell G3 15 3590 Gaming Laptop
        by AustinCER
        I am in search for some help in identifying the LCD FPC. It is a connector for a plug-able eDP cable.
        Attached is a photo of the FPC.
        Model: Dell G3 15 3590 Gaming Laptop
        ST: 79QYJT2
        Thank you very much in advanced....
        11-03-2025, 02:55 PM
      • Weelcup
        XPS 9520 not powering up. Solid orange led
        by Weelcup
        Hi friends
        I have a dell XPS 9530 which had some liquid damage to the usb area. I replaced both the usbc iCs and not I can see 20v on the meter. But it does nothing and the 20v is not passing to charge the battery or turning on the board either.
        I suspected the PD controller (usbc controller) but it will need to be flashed if I decide to replace it. I thought that if the usbc controller needs flashing then at least the board should turn on on the battery. I charged the battery externally and attached it to the laptop. Now the 11.8v is actually passed to the board I can...
        10-20-2025, 04:22 PM
      • RetroComputingGrotto
        Need Help Identifying A Diode
        by RetroComputingGrotto
        I have an MSI 3PA1 monitor on my bench that wont power on. I have tested the 2 (what I believe to be Schottky Diodes) and both are shorted in both directions (a common faulty from what I can see on Google) but I'm not certain what the markings on the Diodes mean so I need some help in identifying which ones to order from Mouser please?
        I've done a search for 101C 5100C and all I can find are datasheets for 5100C which say they are 20-100V 5A Schottky Diodes but I'm not 100% sure if this is correct or not and what significance the 101C is.
        We...
        09-22-2025, 06:47 AM
