Soldering question
  • c_hegge
    • Sep 2009
    • 5219
    Re: Soldering question
    The problem is actually with the thermometer. It is stuck at 500*C and it stops the iron from heating. My solution was just to short the thermocouple with some wire, so that the gauge says 0 and the heater stays on constantly. It probably runs at more like 600*C now, but I haven't had too many problems with burning traces or anything.
      • 31219
      you should check that, it's usually a thermocouple that generates a voltage rising with temperature.
      very reliable, but sometimes the cable between the iron & base breaks.
      what make/model is it?
      • jeff6666p
        • Jul 2014
        • 27
        • us
        I got my pump in today. I put some new solder on the hole with the leg stuck then used the pump, did it on both sides and the leg came out. I did it with the 25w one I have now the hakko one wont be in until tomorrow. What is the way to get ic chips off?
        • jeff6666p
          • Jul 2014
          • 27
          • us
          Thanks for everyone's help.
          • JASTECH
            • Jul 2014
            • 27
            • U.S.A.
            Jeff, To get ic's off I use my Desoldering Station's hot air gun, turn up temp to what's needed and turn up the pressure also same way. I would of already had the correct nozzle on it, then it will melt both sides of solder, then lift ice out with ESD safe tweezers.
            • JASTECH
              • Jul 2014
              • 27
              • U.S.A.
              #26
              Oopps, sorry Jeff answered for myself. Use your new Hakko and some braided desoldering wire, heat & pull braid over legs.
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • Geeker007
                Friend messed up my laptop motherboard while working on my bench
                by Geeker007
                Hi All,
                So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                I have not tried putting...
                06-16-2025, 01:40 PM
                Multifix 425-01 and 450-01 Rework Flux Datasheet
                REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                - No Clean Formulations
                - Low residue
                - Range of activity to deal with different component solderability
                - Halide free
                - Suitable for dispensing
                - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                Both products are supplied in syringes or cartridges for application by dispensing....
                10-07-2024, 06:02 AM
              • petemanuk
                BGA solder balls not connecting - help pls
                by petemanuk
                So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                11-16-2022, 05:21 AM
