finding the uf, the correct voltage, diameter, lead spacing, etc,etc.,
is easy enough, but what are the rules regarding things like ripple current
and/or impedance when considering replacements?
Or should an effort be made to actually find the series of the existing
(burned out) caps? Anything else to consider?
Appreciate any guidance.
The motherboard in question is a 12 year old PCchips KM266 pro
version 9.2a. My son is asking me to save his existing system
because he has so much stuff installed.
Five of the bad caps are to the left of the HSF (voltage regulator?) Close to where the 4-pin
CPU wire plugs in (yellow and black leads. The other two are below the HSF.
4 of them are 16v 1500uf and 3 are 6.3v 3300 uf. All are 10mm wide 25 tall.
TIA -
Dave
TIA -
Dave
