How can you find out about local re-cappers/service? (ex. Brooklyn NY USA)
  • ja1870
    • Jul 2014
    • 16
    Hello from a newbie,
    In general, are there useful ways to find out about local re-cappers/service?
    Or maybe it's just not something done, except under very unusual and specific circumstances?
    It's never been a heading in the yellow-pages. Never yet came across a neighborhood "computer" store (or a rare "TV/Appliance" store) which fixes rather than swaps boards, if the item is not junked. Not going to find any info at the local Radio Shack (which is all about cell phones). Considered audiophile or music equipment stores, but they seem to be few and far between. A pro, a tech school grad, an EE or Physics department?
    Caps gone bad seem the bane of many types of consumer electronics manufacturers consider "disposable". Especially for things that are discontinued, or only still-made to be available at the "high-end".
    Most recent example: my cousin (in Brooklyn) is probably willing to gamble (within reason) that the couple of visibly vented capacitors seen when he opened the case of a useful DVD recorder, are all that is wrong with the unit which suddenly stopped powering on (fuse on same sub-board is OK).
    Personally have no soldering equipment/experience for PCB-level work, and no idea how to look for such a service in Brooklyn (or even where I am in central NJ).
    Could the eBay advertised "PSU-fix" type services be a credible by-mail option?
    Or maybe re-capping/board repair is so uncommon that it's simply unaffordable on a consumer-level?
    So thought to ask for comments here…
    Thanks.
    PS Being brand new around here, also going read the FAQs and posts to try to learn how to source replacement capacitors. There's a lot of printing on the bad ones and not sure what's important besides the basic values.
    RJF, 35 V(m), 56uF, ELNA, CE105˚C, 0427, (S)
    RJX, 16 V(m), 680uF, ELNA, CE105˚C, 0449, (S)
    RJX, 10 V(m), 820uF, ELNA, CE105˚C, 0502, (S)
  • c_hegge
    • Sep 2009
    • 5219
    Re: How can you find out about local re-cappers/service? (ex. Brooklyn NY USA)
    As far as I know, Topcat here is the only commercial recapping service in the US (or maybe even in the world). I know Topcat and kc8adu would probably recap your board, but they are not based near you, so you would have to send your board to one of them.
    • R_J
      • Jun 2012
      • 9589
      did you try googling "Electronic repair in Brooklyn", or check the yellow pages under tv or audio repair? I know there arn't as many around as there was, but there should be a couple repair shops left.
      • ja1870
        • Jul 2014
        • 16
        Thanks for the comments.
        Yes, although he found the two very closest shops didn't do board-level work, he's still checking into more locals.
        And embarrassingly, must have somehow missed the possibility of the proprietor of this forum... I'll send my cousin the contact link.
          by Vesko356
          08-11-2023, 03:27 AM
        • Ancient1
          Need to identify/find a Local buck/boost IC or comparable replacement. MI Streamer
          by Ancient1
          Hi
          Check out the photo : on the left is the blown IC ( bottom right) and on the right is same one : 6-pin AVBM .065 IC
          I can't find ANY mention of it online .
          The streamer is : Mi Box . Model MDZ-22-AB
          Thanks in advance...
          02-19-2023, 05:18 PM
        • danielgerman681
          ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
          by danielgerman681
          Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
          08-27-2025, 01:17 PM
        • corrize
          Where to find a very small fpc connector 0.3mm between 2 pins ?
          by corrize
          Hello, I search this connector (oxydated).
          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
          Do you know how to find this connector please ? What is the exact name for find it ?
          08-06-2024, 05:25 PM
          Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
          This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
          Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
          07-07-2024, 02:34 PM
