Randmusr's 2000-2003 radial replacement thread *pic overload*
  • randmusr
    • Oct 2024
    • 21
    Soltek SL-865G 775
    6x 3300uf 6.3v
    I realize now I could have polymodded this. But @ 3x the cost of these FR these will do!
  • randmusr
    • Oct 2024
    • 21
    MSI 815E Pro
    8x 1500uf 10v
    • randmusr
      • Oct 2024
      • 21
      MSI K7T Pro Ver1
      4x 4700uf 6.3v
      • randmusr
        • Oct 2024
        • 21
        Gigabyte GA-8SG800
        19x Various 3300uf 6.3v, 1500uf and 1000uf
        • randmusr
          • Oct 2024
          • 21
          Albatron KM18G-Pro
          16x Various 3300uf, 2200uf & 1000uf
          • randmusr
            • Oct 2024
            • 21
            Jetway 663AS Ultra 3dfx Voodoo 2 PC
            4x 1500uf
            • randmusr
              • Oct 2024
              • 21
              Epox 8RDA+
              24x 3300uf 1500uf & 1000uf
              • randmusr
                • Oct 2024
                • 21
                Epox 8RDA3+
                18x including 6x polymer
                • randmusr
                  • Oct 2024
                  • 21
                  ECS P4S5A
                  18x mostly 1500uf 6.3v & 1000uf 10v + 1 3300uf (will do the rest of the VRMs in time)
                  Saved the 'worst' board for last. Runs perfectly. Just needs a new CPU retention bracket.
                  • randmusr
                    • Oct 2024
                    • 21
                    ABit NF7-S Rev 2.0
                    3x 1000uf 10v ZLH
                    Not sure why they covered this board in Rubys only to let KZG in around the AGP port. Other NF7 boards here that are non -S inc S2G do not have any KZG & use only Rubys.
                    • randmusr
                      • Oct 2024
                      • 21
                      These motherboards are all part of my initiation to recapping. I've had the privilege of learning to remove them with a desoldering gun, a Hakko FR-301. It was a sizeable investment but easily the best tool ever.
                      All boards have been fairly well stress tested for many hours in the Serious Sam 1 TFE OG demo loop, and 3dmarked, and all are stable and function well.
                      Also every one of these boards bar the NF7 were tested prior with no life at all. No post & no beeps. Each one was a hail mary so to revive them all was a nice surprise.
                      There are a still quite a few caps on these boards that could be swapped out, but I've mostly gone with what visually looks bad. There are known suspects across a few, like the inputs on the 8RDA3+ & P4S5A but I'll wait for the boards to play up, if they ever do.
                      • Dan81
                        SNES-powered
                        • Oct 2013
                        • 1866
                        • Romania
                        Nice, I had a few valuable boards go thru recap, with QDI's BrillianX 1 and Chaintech's 6BJM0 being up next soon.
                        A few of them.
                        BP6:
                        MSI MS-6168, Voodoo 3 2000 onboard
ID:	3513556 Click image for larger version
ID:	3513557 Click image for larger version
                        Epox EP-51MVP3E-M 1MB
                        MS-6163 rev1, VRM low is almost all poly
                        Main rig:
                        Gigabyte B75M-D3H
                        Core i5-3470 3.60GHz
                        16GB DDR3-1600
                        Samsung SH-224AB DVD-RW
                        Delux MG760 case
                        • randmusr
                          • Oct 2024
                          • 21
                          They look really good, and vs the boards I did, are way more valuable. I like the BX board polymod.
                          When I first started there was a lot of stitch work not too great but after completing a few more I went back and fixed them up. Even after 250+, I still run into a few unfriendly joints at times.
                            • 31138
                            heat the area with hot air before and while your soldering
                            • randmusr
                              • Oct 2024
                              • 21
                              Like a rework station like the Yihua 858D or whatever it's called?
