I'm repairing the motherboard on a friend's Toshiba Satellite L305-S5919, and was hoping someone on the forums would be kind enough to help verify or double-check that I'm buying the correct caps.
Here's the data:
Motherboard: Intel 6050A2170401-MB-A03
Replacing: NEC/TOKIN OE907 Proadlizer (900uF/2.5V)
After scanning several blogs, most folks recommend replacing the craptastic Proadlizer with Tantalum capacitors. However, different folks report using different numbers and specs, and I haven't seen any mentions of this exact motherboard. As I'm clueless with the down-n-dirty electrical jargon and whatnot, I'd rather poll the experts here than take a chance.
The closest matches I've found are posts for replacing the same Proadlizer, here on BadCaps and on Tom's Hardware. Here, it is replaced with 1x 100uF and 5x 10uF, and on Tom's it's replaced with 4x 470uF/2.5V each and 2x of 220uF/2.5V. However, I'm having a difficult time finding these exact capacitors.
So, do I NEED these exact capacitors? Or, can I play with the voltage, uF, ESR? If so, within what ranges?
Here's the numbers again for quick ref:
Proadlizer: 900uF/2.5V
Option 1: 1x 100uF and 5x 10uF (2.5V?)
Option 2: 4x 470uF/2.5V each and 2x of 220uF/2.5V
Sorry for my ignorance. Any help would be much appreciated!
Thank you,
~Lokki
Here's the data:
Thank you,
~Lokki
