215-0752007 Alternatives
  • LukeDavis
    • Feb 2022
    • 26
    Hello!
    as part of my hobbies i like to practice and toy around with older equipment, as such i have two older notebooks with AMD 215-0752007 Chipsets, both units have died, with only one (a G62-a15SA) still working if "Baked" first.
    i believe i had a discussion with somebody a while back elsewhere about something similar, while browsing the forum i discovered there are other chips which can work but require slight board/bios modification.
    i also know that some chips from later years have better reliability but checking a certain online supplier (Chipbay) they claim to be selling a similar chip from "2019+" i absolutely do NOT trust this claim, hence why i am searching for pin compatible drop ins.
    i suspect certain versions of these chips (typical AMD/ATI) are poorly cooled, overheat and fail, though bump gate is probable.
    I know it may be a little weird me wasting time and money on these old things but I find it beneficial to my knowledge, any advice or help would be amazing
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 215-0752007 Alternatives
    "More reliable" ICs don't exist for this (unlike some of the bad 2006-2008 Nvidia ICs). AMD had poor reliability across the board with these generations, both on the GPU and chipset parts (CPU were generally fine). That said, with proper cooling and a little bit of luck, they still should last at least a few years.
    It's also difficult to find actually good new ICs. see-ic had some at some point, but they got more expensive over time, and their website has been broken for a while and their eBay store neglected.
    Many other sellers (and even see-ic did) sell garbage "refurbished" ICs, ie. old garbage generally already failed but polished and remarked with newer datecodes, and sometimes different part number.
    As for cross-compatibility between parts of these series (RS780/RS880), best place to find information is on Russian-speaking forums such as vlab . su and ascnb1.ru. Depending on the board, some may work out of the box, some may require editing the BIOS to change VBIOS PCI id, and some may not work at all. Always better to use the same part number to avoid headaches and waste of time and money.
    Sadly I think we are reaching the end of the line in fixing these boards. At least a bunch of laptops have an equivalent Intel chipset board (without AMD dGPU) that can be swapped (along with the heatsink, and sometimes requiring some additional modifications). Will perform better, generate less, be much more reliable, and sometimes have less compatibility issues with some OS.
    • ugamazing
      Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
      by ugamazing
      I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
      08-31-2022, 07:34 AM
    • feherhollo
      WSON8 NEW Bios Chips READ, ERROR, ETC.
      by feherhollo
      I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
      I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
      For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
      11-26-2023, 09:33 AM
    • Prott
      [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
      by Prott
      Hello dear badcappers!
      The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
      Backstory:
      After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
      If there is a way to narrow down which memory module is faulty it would make my life much...
      06-03-2024, 12:05 PM
    • LukeDavis
      Is there a list of known dodgy ATI Radeon chips?
      by LukeDavis
      Hello again! (People are likely going to get tired of seeing posts from me lol)
      I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
      While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
      1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
      2. ATI Mobility Radeon X1600 and the...
      02-16-2024, 04:34 PM
    • H34TO
      ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
      by H34TO
      Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
      06-17-2025, 07:17 AM
