Capacitors instead of RTC/CMOS batteries
This topic has been answered.
  • STKR123
    • Jun 2023
    • 12
    • Country
    Hi, would there be somekind of knowledgebase for laptops, that are using capacitors (+laptop battery) instead of RTC/CMOS batteries for keeping BIOS/UEFI values "alive/stored"?
    I learned hp and lenovo are doing this on their newer models a lot. I myself have a 2016 ASUS X540L here, that has not RTC/BIOS battery.
    Id like to know what to look for on the mainboards.
    Thank you in advance.
  • Answer selected by STKR123 at 08-30-2024, 10:55 AM.
    stj
    • 31287
    bios settings are in flash,
    the rtc is built into the bridge chip and probably powered by a lithium rechargeable battery soldered to the board.
    super-capacitors as they are called are shit - companies tried them and mostly dropped the idea.
      • 31287
      • STKR123
        • Jun 2023
        • 12
        • Country
        Ah, "super capacitor".
        Now I found some more things to consider and to read.
        https://www.badcaps.net/forum/genera...uper-capacitor
        Thank you!
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          Stj just said it. While I do have some success with large super capacitors, the small one are a pain in the rear. If you want you can read my Fluke 289:super capacitor thread. That is one device for example where the manufacturer went from super caps to battery.
          • aurgathor
            • May 2012
            • 16
            Super caps are good when they need to provide power for a short time [seconds, maybe minutes], such as in a dash cam after the ignition is turned off.
            They need to power it long enough to close files and do an orderly shutdown -- which shouldn't take more than a couple of seconds. Unlike batteries, their capacity won't change much, so they're a better option in that particular use.
              • 31287
              they leak - they have no safe use
              • 370forlife
                Large Marge
                • Aug 2008
                • 3113
                The original Xbox used a supercap. It was a 2.5v 1F cap and they are prone to failure. As long as the xbox was connected to mains, it would keep the cap charged and maintain the date/time. They expected that this would be the case as most people just leave their consoles plugged in all the time. In the event it was unplugged or there was a power failure, the cap would last a few hours or so before completely discharging.
                • aurgathor
                  • May 2012
                  • 16
                  Evidence please showing that this is a widespread issue.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8352
                    That’s true for the small supercaps. The big ones do not have that leaking problem. I am running an experiment using large supercaps (two 25F in series) and with a solar panel and some device for 8 years now and all is good. The small supercaps just keep looking at the fluke 289 thread.
                      • Jul 2011
                      • 6070
                      I have used the lager super cap before with out any issues but I was not aware of issues with the smaller version of them because I used one in a project for a company that had a storage tank for sanding blasting material and wanted to how much material was in the storage tank I used it for a memory retention time chip and I tested it several times for several hours and retained it memory
                      I no longer work for this company anymore but the last time I talked to a person who used to work there a couple years later said that they were still using so who knows now if it is still working or not this was over 15 years ago
                      • aurgathor
                        • May 2012
                        • 16
                        To me that looks like *one* bad cap in one particular product. Or in the XBOX, but I have not seen any indication that this is a widespread issue. I do know that with regular caps, certain years from certain manufacturers can leak, but that doesn't apply to all caps. I have at least a couple of devices (i.e. dash cam) with a supercap, and had zero issue with them. I know that's a very small sample size, but on the other hand I've had bad cap issues with probably over 2 dozen pieces of equipment over the years.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8352
                          It’s similar to regular capacitors. Little ones are usually they go bad and the big ones are better and last. How long, I have no idea.
                          For example: My first CFL bulb I bought 22 years ago, is still working, while most CFL bulbs is the house went dead and got replaced for LED. I still got one 19 year old incandescent bulb running. Some things run longer than others, even so it is the same product.
                            • 31287
                            they leak in sega arcade equipment leading to trace repairs
                            they used to leak in vrc's but it was a minor issue because they used single-sided boards.
                            the only ones that didnt leak were the old ELNA ones that were in thick steel cans - they probably knew something!
                            • carrzkiss
                              Cyberpower cps1500avr not charging batteries
                              by carrzkiss
                              Hello, all.
                              Cyberpower Battery Backup Unit.
                              I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                              When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                              In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                              Checking the voltage, it was down to 22v.
                              I quickly removed everything...
                              06-15-2024, 02:10 PM
                            • questore
                              XPS 13 9370 CMOS battery voltage always low
                              by questore
                              Hi Everyone,
                              I have brought you a mistery item
                              This laptop have come with some strange faults.
                              1. CMOS battery was flat 0v
                              Symptoms:
                              - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
                              Amp drawing was stuck at 0.005 milliamps.
                              - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
                              After inverstigation RTCD1 diode had a low value...
                              09-30-2025, 05:47 AM
                            • Genghis_Khan
                              ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                              by Genghis_Khan
                              I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                              Issue summary:
                              Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                              However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                              11-11-2025, 11:51 AM
                            • dragon3x
                              by dragon3x
                              power on.
                              Here are some examples :
                              switching supply area).
                              than 6.3 V.)
                              03-21-2025, 02:46 PM
                            • howardc64
                              Where do repair shops buy MB replacement batteries?
                              by howardc64
                              Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                              Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                              BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                              07-25-2024, 10:42 AM
