Recapped two boards, both working fine
  • Battleweary
    • Apr 2007
    I bought a Soltek KT333 chipset motherboard off of ebay. When it arrived, I took it out of the box to find that it had four swollen, leaking caps on it. I contacted the person that I bought it from and told them about it. They told me that they hadn't even noticed them, so they gave me my money back and told me to do what I wanted with the board. Some time later, I was over at the VIA arena forums and they actually had a Soltek representative that posted in there. I told them about the board, so they took my name and address and about two weeks later I received an envelope from Taiwan. Inside was a bag full of brand new caps. I replaced the bad caps on the board, and it has been running my CS:Source LAN server ever since.
    This one is even better. I bought another board from ebay, this time an MSI KT3 Ultra. It had twelve bad caps on it, all of them were the 1000 microFarad,6.3V ones. It was running in my daughters computers for a while, but was giving blue screens quite often and would sometimes not boot unless I unplugged the power supply for a few minutes. I took a dead Socket 370 board that had all good caps on it and pirated nine of the caps I needed from it. I then soldered them onto the MSI board, along with three brand new ones that I got from Soltek. No more blue screens, no boot problems, and all the voltages are right on in Everest.
    Another little trick for replacing caps: When there is still some solder in the hole and you can't put the lead through for the new cap, just hold the new cap in position and press lightly on it while heating the solder from the back side with the soldering iron. The solder becomes soft enough that the lead pops right through. Just FYI.
  • yanz
    • Nov 2004
    • 910
    Re: Recapped two boards, both working fine
    always nice to hear a successfull recapping i bet that what soltek rep gave you were panasonic fj caps... (or not..)
    • tazwegion
      • Jun 2006
      • 444
      Hmmm... I have that exact same board, the 1000uF 6.3v components are the notorious Teapo, the remainder on the board are Nichicon HM's (3) & FJ's (9), I'm curious if that board (of yours) ever had a quirky HDD detect? mine IIRC continued to auto detect the drives despite being configured in BIOS
      Perhaps, if I ever get around to replacing the Teapos I'll find that odd quirk (for which I pulled the board from service) will disappear
      Viva LA Retro!
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
        After all of...
        07-13-2024, 08:14 PM
