Tantalum Capacitors and Heat Sensitivity
  • Perry Babin
    • Apr 2024
    • 15
    • usa
    I remember reading somewhere, years back, that tantalum capacitors are sensitive to heating on their negative terminals and using more than a minimal amount of heat could result in damage. Is this/was this ever true?
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    No idea on that one, but I have only read that Tantalum caps are extremely sensitive to even the slightest of reverse voltage and can easily short-out afterwards.
      • 31055
      unlikely,
      firstly why the negative?
      second, we have SMD tantalums now.
      they hate reverse polarity though - even short spikes can wreck them.
      always overate the voltage by atleast 100% if you can.
      so for a 12v rail DONT use 16v caps - put 25v caps in
      • Perry Babin
        • Apr 2024
        • 15
        • usa
        The positive terminals are welded, internally. The negative terminal's internal connection varies. I've seen conductive epoxy, solder, silver adhesive... If this problem is new to those who frequent this forum, it's likely not an issue in real world use. I think what I read was for hand soldering.
        • redwire
          • 3910
          There are several different tantalum capacitors - dipped/bead, solid, wet-slug, SMD. Then there is their construction, the seal on the anode for the can types - usually glass for hermetic MIL types.
          Never heard or seen issues about soldering them, maybe there was a period of using a plastic for a seal on a wet cap?
          Today, they take wave and reflow soldering no problem.
          https://=https://www.vishay.com/docs...capsbasics.pdf
          • slybunda
            AA and AAA battery charger capacitors?
            by slybunda
            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
            it has inside:
            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
            2 x 470uf 16v LZ105c branded as G.Luxon
            not heard of these brands are they any good?
            iv attached photos of the charger and the board inside for an idea on the type of...
            12-24-2023, 04:41 AM
          • dragon3x
            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
            by dragon3x
            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
            power on.
            Here are some examples :
            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
            switching supply area).
            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
            than 6.3 V.)
            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
            I replaced capacitors with aluminum-polymer.
            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
            03-21-2025, 02:46 PM
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
          • Ady2017
            Are there any datasheets available for Elna RJG capacitors?
            by Ady2017
            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
            05-25-2025, 02:19 PM
          • ctroxtell
            Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
            by ctroxtell
            I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
            01-03-2025, 08:57 PM
