Tantalum Capacitors and Heat Sensitivity
  • Perry Babin
    • Apr 2024
    • 22
    • usa
    I remember reading somewhere, years back, that tantalum capacitors are sensitive to heating on their negative terminals and using more than a minimal amount of heat could result in damage. Is this/was this ever true?
    master hoarder
    • May 2008
    • 12175
    No idea on that one, but I have only read that Tantalum caps are extremely sensitive to even the slightest of reverse voltage and can easily short-out afterwards.
      • 31293
      unlikely,
      firstly why the negative?
      second, we have SMD tantalums now.
      they hate reverse polarity though - even short spikes can wreck them.
      always overate the voltage by atleast 100% if you can.
      so for a 12v rail DONT use 16v caps - put 25v caps in
      • Perry Babin
        • Apr 2024
        • 22
        • usa
        The positive terminals are welded, internally. The negative terminal's internal connection varies. I've seen conductive epoxy, solder, silver adhesive... If this problem is new to those who frequent this forum, it's likely not an issue in real world use. I think what I read was for hand soldering.
        • redwire
          • Dec 2010
          • 3912
          There are several different tantalum capacitors - dipped/bead, solid, wet-slug, SMD. Then there is their construction, the seal on the anode for the can types - usually glass for hermetic MIL types.
          Never heard or seen issues about soldering them, maybe there was a period of using a plastic for a seal on a wet cap?
          Today, they take wave and reflow soldering no problem.
          https://=https://www.vishay.com/docs...capsbasics.pdf
          • slybunda
            AA and AAA battery charger capacitors?
            by slybunda
            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
            it has inside:
            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
            2 x 470uf 16v LZ105c branded as G.Luxon
            not heard of these brands are they any good?
            iv attached photos of the charger and the board inside for an idea on the type of...
            12-24-2023, 04:41 AM
          • dragon3x
            by dragon3x
            power on.
            Here are some examples :
            switching supply area).
            than 6.3 V.)
            03-21-2025, 02:46 PM
            After all of...
            07-13-2024, 08:14 PM
          • Cama
            Solar Inverter - SMH-II - 2 missing capacitors
            by Cama
            I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
            My model is : EASUN SMH-II 7 KW
            Mother Board : P/N 18947-002401250250
            Maybe the EASUN SMH-II 4.2 KW have the same capacitors
            Thank you...
            09-12-2025, 02:50 AM
          • Ady2017
            Are there any datasheets available for Elna RJG capacitors?
            by Ady2017
            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
            05-25-2025, 02:19 PM
