Unsold Plague Capacitors
  • Perry Babin
    • Apr 2024
    • 22
    • usa
    What are the chances that plague capacitors are still in stock and being sold?
    • 31260
    depends on your source - ebay probably cant be trusted.
    • dmill89
      • Dec 2011
      • 2534
      ^This, they should be well out of the inventory of major suppliers by now (DigiKey, Mouser, Newark, etc.). But I'm sure there are some still kicking around somewhere. Ebay is loaded with counterfeits as well as old inventory.
      And while the true "plague era" caps should be largely gone by now (there is a good chance that most remaining would have bloated in storage by now, and if not the likely will quickly after power is applied), there are still new production sub-par caps out there that aren't reliable (particularly from the "less reputable" brands).
      • Perry Babin
        • Apr 2024
        • 22
        • usa
        I was hoping to hear that the manufacturers bought back all defective caps but it's more likely that they were sold.
        Yes. Amazon and Ebay are bad for counterfeits, especially obsolete semiconductors, which they always have readily available.
        I don't see much on Cornell Dubilier caps. I used quite a few and still recommend them. Is there a reason they aren't commonly mentioned? Quality? Price?
        I deal with a lot of people (tech support) who blindly replaced capacitors (many plague caps) in their beloved collections (mainly amplifiers) and put them into storage. It's a shame that many will be damaged by leaky caps when the originals would have done no damage.
        • dmill89
          • Dec 2011
          • 2534
          I'm not aware of any such buybacks (and only the more reputable manufactures would even consider such a thing), but even if that did occur, defective/recalled products often have a way of "leaking" out into the wild (often claimed to be disposed of but smuggled out of the factory/warehouse and resold instead).
          I've used them before with no issues, and they are generally regarded as a good/reputable manufacture. The main reason they aren't commonly mentioned here is likely that they aren't a major player in low-esr/computer grade caps which are the most common subject of posts on this forum.
            • 31260
            i dont even see dubiliier caps at my suppliers,
            when i did i used the low esr red ones to repair psu's and they never failed.
              master hoarder
              • May 2008
              • 12175
              It wasn't too long ago when I saw a bunch of (NOS) Rubycon MFZ (the 6.3V 2700 uF variety that like to bulge in storage / without use) on eBay - maybe about 3-4 months ago.
              So yes, you can still find "plague" -era Japanese caps. Same with UCC KZG series. In fact, some sellers are unaware of this and even have pictures of their stock on which you can clearly see some of the caps bulging and/or leaking.
              As for crap-cap brands - those are still sold everywhere and will likely continue to be sold for many many more years, if not indefinitely. Same with garbage (counterfeit) silicon parts.
              • dragon3x
                by dragon3x
                power on.
                Here are some examples :
                switching supply area).
                than 6.3 V.)
                03-21-2025, 02:46 PM
              • slybunda
                AA and AAA battery charger capacitors?
                by slybunda
                hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                it has inside:
                2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                2 x 470uf 16v LZ105c branded as G.Luxon
                not heard of these brands are they any good?
                iv attached photos of the charger and the board inside for an idea on the type of...
                12-24-2023, 04:41 AM
                After all of...
                07-13-2024, 08:14 PM
              • Cama
                Solar Inverter - SMH-II - 2 missing capacitors
                by Cama
                I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                My model is : EASUN SMH-II 7 KW
                Mother Board : P/N 18947-002401250250
                Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                Thank you...
                09-12-2025, 02:50 AM
              • Ady2017
                Are there any datasheets available for Elna RJG capacitors?
                by Ady2017
                I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                05-25-2025, 02:19 PM
