Gemcon capacitor replacements?
  • slybunda
    • Feb 2012
    • 131
    taken from my thread about car alarm siren here: https://www.badcaps.net/forum/troubl...rm-siren-issue
    there are 2 caps which im looking to get replacements for.
    Branded as Gemcon
    single 100uf 16v 6.5mm x 11.5mm
    single 100uf 50v 8mm x 11.5mm
    lead spacing is around 3mm
    there is space for 16mm tall caps
    rs components is good place for me to go since its close by, what replacements do you suggest and do these need to be low esr?
    the caps have not swollen up but this alarm was fitted in 2002 so i suspect caps are probably older so maybe coming on 25 years old so would be worth replacing.​
  • andrewsawesomr
    • Jun 2022
    • 100
    • United States of America
    Could you measure the ESR on the capacitors?
      • 31020
      look for a 3 letter code on them
      https://www.paullinebarger.net/DS/Gemcon/
      or just use panasonic FR or rubycon YXF/YXG for long life
      • andrewsawesomr
        • Jun 2022
        • 100
        Gemcon capacitors don't put the series code on the sleeve.
        • slybunda
          • Feb 2012
          • 131
          That explains why i couldnt find it on the caps.
          Gemcon website says they are made in tiwan so guessing they are decent quality?
            • 31020
            lol
            if they were decent they would print the series and datecode on them and not just use a generic sleeve
            • andrewsawesomr
              • Jun 2022
              • 100
              lol
              Yeah, they're not decent.
              • Tom41
                Honeywell Accenta G3 tamper alarm
                by Tom41
                This house has a Honeywell Accenta G3 alarm system. If the main unit loses power for any reason, the external siren sounds - even if the alarm is not even armed! Entering the code to disarm it is not an option as the keypads are completely dead when the power is out.
                I presume this means the backup battery inside the box has failed, but I can't get in there and replace it without also setting off a tamper alarm! Is there any way to disable the tamper alarm so that electrical work can be carried out with the power off? Or a way to replace the backup battery without setting off the...
                08-31-2023, 04:00 AM
              • slybunda
                Alarm Siren issue
                by slybunda
                Apologies if this is in the wrong section but being a car alarm siren that makes noise i thought it be best to put it in the audio section.
                Had weird alarm issues where siren made a strange noise: https://www.youtube.com/watch?v=ZjsqndhionU
                took siren out of the car and checked it out and pics attached seem to be the source of the issue.
                shockingly the alarm still makes its normal sound if i trigger it manually so speaker seems to be intact.
                getting a replacement is gonna be next to impossible, its a Toad Ai606 which is no longer in production and cant see to find a replacement...
                02-04-2024, 11:01 AM
              • Ady2017
                Does anyone know about 16x2 LCD screens used in alarm keypads?
                by Ady2017
                I have got an old Gardtec GT595 alarm which has got a faulty keypad with a failed LCD screen. This was apparently a very common problem with these and many people have had to replace the whole alarm because of this problem. Somebody claims to be able to repair the keypads by replacing the screen and I have tried it myself by replacing the LCD with a commonly available HD44780 1602 16x2 Serial LCD screen but it is not working. I am sure it is a problem with a driver or simular which is not allowing the screen to talk to the rest of the electronics. Does anyone know what this original screen was...
                06-02-2025, 04:56 PM
              • Mcfeetroy
                Fishing bite alarm drains battery
                by Mcfeetroy
                Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                08-01-2025, 03:52 AM
              • redwire
                Honeywell/Ademco Wave2 two-tone siren - recap, sch, pics
                by redwire
                My garage alarm siren was sounding a bit quiet and the tone was weird, like mixed with another tone.
                Powered up it draws about 14V 300mA with a spike to ~1A briefly during the low pitch yelp, seems normal.
                Teardown reveals only two electrolytic capacitors inside, so I replaced them. 100uF 25V for the warble ramp, and 47uF 16V for decoupling.
                The old ones tested OK sort of? - 100uF reads 68uF (-32%) ESR 0.80Ω, and 47uF reads 41uF ESR 0.87Ω as well so it was a bit confusing if the caps were to blame.
                The tone caps are green film caps I left alone. Newer...
                07-30-2023, 08:21 PM
