AA and AAA battery charger capacitors?
  • slybunda
    • Feb 2012
    • 131
    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
    it has inside:
    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
    2 x 470uf 16v LZ105c branded as G.Luxon
    not heard of these brands are they any good?
    iv attached photos of the charger and the board inside for an idea on the type of application these caps are in.
    now i do have a pack of new capacitors in stock at home here which are 470uf 16v part number: EKY-160ELL471MH15D purchased from here: https://uk.rs-online.com/web/p/alumi...citors/8118663 branded Nippon Chemi-Con. are these suitable replacements for the ones in the charger? the height of the caps i have seem to be a little taller than the originals but iv checked that there is room in there to fit them.
    as for the 47uf caps any ideas on if should replace them if so with what type? iv found a few options here but not sure if they meet specs in ripple, esr etc: https://uk.rs-online.com/web/p/alumi...citors/2244167 and https://uk.rs-online.com/web/p/alumi...citors/2286644
    thanks
    • 31086
    nice design,
    the only one that could be stressed is next to the big coil.
    if you choose to re-cap it then just use panasonic FR
    • slybunda
      • Feb 2012
      • 131
      Can i use the nippon chemicon ky cap i have for replacing the 470uf cap or it not the correct series type for this type of application?
        • 31086
        KY 0.087ohms 840mA 8mm diameter 6000hour
        FR 0.056ohms 950mA 8mm diameter 6000hour minimum life
        close - choose based on price.
        • slybunda
          • Feb 2012
          • 131
          I already have the KY caps at home here new in a pack of 20 so no need to go out and spend money if they are suitable for use in this application.
          as for the 47uf caps can i use these: https://uk.rs-online.com/web/p/alumi...citors/2244167
          They are rubycon YXF series 5000h 150ma
            • 31086
            suscon SK are standard crap other than being 105'
            so YXF is much better anyway.
            • slybunda
              • Feb 2012
              • 131
              Excellent with get the rubycons yxf and use them with the ky caps i already have to recap this charger.
              I thought suscon are supposed to be half decent maybe on the level of capxon and teapo?
                • Jul 2011
                • 6041
                You can also use the automotive type from from the same manufacturer that the “KY,KZE” are from I use these series all the time and not had any issues using them in switching power supply I also some series from
                Rubycon as well and the some series that are “FC,FR” from this manufacturer as well it sometimes depends on whether or not one manufacturer has the right size in diameter and height to which series that I use
                • slybunda
                  • Feb 2012
                  • 131
                  Are automotive ones cheaper? Any advantage to using them?
                    • Jul 2011
                    • 6041
                    Not necessarily cheaper but not necessarily more expensive however they are made to stand up for more heat environment but you do not find all of the UF values like you might might find in other series and other manufacturers and in diameter and length range of sizes
                    If I know that I am going to used them in a switching power supply and it going to be used in a harsh environment and the UF values are available and the diameter and length are available and the ripple current is nearly the same as let's say like a “KY or a KZE in the same diameter and length size I would buy of some of each UF from the automotive series and KY and KZE sometimes the automotive series do not have the same ESR resistance value as the other series like KY or KZE but if they are close to each other in that respect then I would consider either of them it just depends on the situation of all of specific values that you are dealing with
                    • slybunda
                      • Feb 2012
                      • 131
                      Thats good to know, any idea what brand and series are automotive caps when it comes to brands like nippon chemicon, nichicon, Panasonic, rubycon etc?
                        • Jul 2011
                        • 6041
                        I do not know off the top my head but it not very hard to find if use Dig-key or Mouser because they show what the series are
                        nippon chemicon LXZ is one of temperature 105*C
                        nichicon = UBT is one of temperature rated 125*C
                        rubycon = RX30 is one of temperature rated 130*C
                        Panasonic =FC is one of temperature rated 105*C
                        There are few more but I do have have the time to find all of them
                        However I personally have not use the UBT or the RX30 so I can not comment on these series with how they work in a switching power supply
                        • slybunda
                          • Feb 2012
                          • 131
                          Picked the 47uf caps up today so will get recapping hopefully later on today
                          • slybunda
                            • Feb 2012
                            • 131
                            Recapping done and charger is working fine. Thanks all for helping on this one
                              • 31086
                              dont pay any attention to AEC-Q200 certification.
                              i have seen caps with that rating leak with age many times.
                              just ask any Honda owner with an OBD1 series ecu!
                              • slybunda
                                • Feb 2012
                                • 131
                                Thats good to know i thought that certification ment they were leak proof.
                                Wondering about my charger would polymer caps be suitable substitute or would there be issues?
                                For example here is a 470uf 16v polymer cap:
                                https://uk.rs-online.com/web/p/polym...citors/7149082
                                Could i have used that in this charger?
                                Also i thought polymer is supposed to have higher lifespan? Why is this one 5000h where the electrolytic cap i used is rated at 6000h?
                                  • 31086
                                  you would need a schematic to know if polymer would be an issue
                                    • Jul 2011
                                    • 6041
                                    Originally posted by stj
                                    Dont pay any attention to AEC-Q200 certification.
                                    So far I have not had any issues with using the LXZ series capacitors and I have used a lot of so far for last 3 or 4 years now
                                    The other series I have not used as many capacitors in devices yet so I can not comment on those at for now
                                    But thanks for the information
                                    • motormayhem
                                      Lenovo T460 Only Charges on One Charger
                                      by motormayhem
                                      Laptop Question
                                      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                      05-12-2023, 01:46 PM
                                      NVDC charger configuration...
                                      11-05-2024, 03:28 PM
                                    • flat-earther
                                      ASUS X54H laptop thinks it's always charging even with charger unplugged
                                      by flat-earther
                                      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                      Windows also shows ''Plugged in'' when charger is not connected.
                                      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                      If I let battery run out and say it has 3% Windows will...
                                      06-24-2025, 09:32 AM
                                    • Johndill
                                      Dell Inspiron 7567 LA-D993P odd charger issue
                                      by Johndill
                                      Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                      There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                      I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                      Here are the tested scenarios:
                                      1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                      2. With the laptop off, plug in charger (LED says on) & the front charging...
                                      11-16-2022, 10:55 PM
                                    • Flaku_34
                                      Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                                      by Flaku_34
                                      Introduction:
                                      Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                                      04-18-2024, 12:47 PM
