Hi friends,
I recently acquired an old PC power supply (along with several vintage motherboards from late 90s/early 2000s). The PSU was dead upon first test, but quickly identified the internal fuse had blown. I fixed that, re-tested and i'm pleased to report it seemed to work great after that - no obvious issues or reasons for the fuse to blow.
Afterwards, I inspected the capacitors more closely and noticed one pair required replacement. They weren't in bad shape by any stretch of imagination, but one was slightly bulged, and I wanted to swap them out for good measure.
The caps appear to be 'Kuang Jin', branded with a 'CS' logo, and has '2200uF 10V +105*C' printed on the side. The only other code shown on the cap is '0303M' - I haven't quite figured out what this means yet.
Now, without being able to track down a datasheet, i'm not entirely sure what to replace them with. I found some datasheets here - https://paullinebarger.net/DS/CS%20%...uang%20Jin%5d/ - but i'm struggling to identify which type they are.
Appreciate any tips here, i'm fairly new to the capacitor replacement game and keen to learn how to identify appropriate replacements, as I have many others to do.
K.
K.
LMAO!
