Blown Cap
  • landyboy
    • Apr 2013
    • 443
    Blown Cap
    This is why you should not buy cheap caps!!
  • c_hegge
    • Sep 2009
    • 5219
    Re: Blown Cap
    Those are not cheap caps. They are Japanese Nippon Chemi-con caps, which should be reliable. I'd say there's something else going on there which caused the failure.
    • landyboy
      • Apr 2013
      • 443
      Re: Blown Cap
      Ok maybe it was just an assumption they were bad caps since they were cheap. Everything worked fine and as we were watching it we heard a loud pop and a lot of smoke. Any suggestion what else could have caused it?
      • landyboy
        • Apr 2013
        • 443
        Re: Blown Cap
        They were new caps I just put in after replacing a bad buffer board.
        • mockingbird
          • Dec 2008
          • 5488
          Re: Blown Cap
          Where did you buy them?
          • ant3202
            • Jun 2006
            • 275
            • Singapore
            Re: Blown Cap
            check polarity or maybe take some pic below on bungs or wat..
            • landyboy
              • Apr 2013
              • 443
              Re: Blown Cap
              Ebay. And polarity was correct, set worked for probably 20-30 hours before it happened.
              • lexwalker
                • Feb 2011
                • 307
                • Malaysia
                Re: Blown Cap
                EBay? Could be counterfeit capacitors...
                • landyboy
                  • Apr 2013
                  • 443
                  Re: Blown Cap
                  That what I was thinking. I ordered new ones from Digi-key. I will pull these and investigate more.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Re: Blown Cap
                    That what I was thinking.....I will pull these and investigate more.
                    What series are these NCC capacitors?
                    From what I can see in the pictures, they are KMG series?!
                    If so, that is a red flag, KMG is not a snap-in type!
                    And, as far as I know, NCC uses '┼' like vents on big snap in capacitors like those, not 'Y' shaped.
                    Muh-soggy-knee
                    • odtech
                      Asus UX490U laptop blown (caps?) on power board.
                      by odtech
                      Greetings friends.
                      I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
                      I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
                      Any guidance...
                      08-06-2023, 10:29 AM
                    • zlr8r
                      HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
                      by zlr8r
                      Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
                      To begin with, this laptop was dead-dead.
                      Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
                      • am getting white power led
                      • 5-long-flashes on CAPS Lock and NUM lock
                      • then, fan full speed
                      • CPU heats up some (smaller die PCH, does not)
                      • always constant black screen no matter what's tried
                      • no USB recognition
                      • no HDMI output
                      this is as far as I can get with it and not sure where to inspect next ?
                      I tried...
                      03-27-2024, 03:13 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • whc14765
                      1070 - Blown SMD caps, short on 12V PCI
                      by whc14765
                      Hey
                      I got a short on 3 pins of the PCI-E gold connector for 12V.
                      I see a few caps near the top right (near main power connector) that look blown, one is showing a short across it to GND.
                      Unforunately I don't have a schematic or board view for it (EVGA GTX 1070 FTW 8GB).
                      Due to the large number of caps there, I think it may just be decoupling.
                      Any ideas on figuring out the cap values? There also isn't any reference numbers for the caps on the silkscreen.
                      11-23-2022, 06:42 PM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
