fake/counterfeit capacitors
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    How often do these show up installed in devices?
    And what properties (capacitance, voltage, ESR, lifetime/temperature rating) tend to be the skimped on fake capacitors?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: fake/counterfeit capacitors
    Usually shows up in cheap, very cheap, devices. Like ebay items, or direct from china stuff.
    The caps tend to be overrated/underrated(85 deg overrated to 105, 220uf overrated to 470uF, etc...), or only spec'd to 1000 hours...
    Muh-soggy-knee
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Then why did one of the folks here report counterfeit Chemi-Con primary caps in a PSU that actually looked reasonable?
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        I did say "Usually"
        The caps had the right text font and correct negative indicator stripe. However, the series the cap was marked for didn't have that capacitance listed, and the plastic sleeve was black, when it was supposed to be brown!
        Muh-soggy-knee
        • japlytic
          • Oct 2005
          • 2086
          I've acutually found them in equipment myself - including Rubycon YXF (low-ESR) in a CD boombox (which did not have a swithcing power supply), 105C black Chemi-Con units (normally, black Chemi-Con units are rated at 85C) and Nichicon (black with silver print) in a universal notebook AC adaptor.
          Also, I've seen Chemi-Con series of which Chemi-Con did not make as far as I know.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            The most common fakes seem to be the primary capacitors on non PFC PSU's. But I've seen a few on some really low end motherboards too. For some of the REALLY low end equipment from China, who knows what you're actually getting
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              I ended up getting a couple of new counterfeits, and took some measurements from them:
              Visual: poor font colors, seals are different
              Capacitance: some are spot on, some are off by 33%
              Voltage rating: Way off. Leakage sucks at rated voltage.
              Lifetime/Temp rating: no way to tell
              What I was wondering if different brand, lower tier capacitors really are worth it to rebadge as a "quality" capacitor, are lower tier capacitors really cheaper (at same ratings) or do they have to really go down to get enough of a profit from counterfeiting them?
              • lexwalker
                • Feb 2011
                • 307
                • Malaysia
                Seen quite a number of fakes/counterfeits especially imitation of brands like Nichicon and Rubycon are much more common. Some of the fakes/counterfeits encountered are Nichicon VZ, Nichicon PW, Rubycon YXA, Rubycon YXF, Nippon Chemicon KMG, etc just to name a few...
                The vents on the top and the seal on the bottom always gives them away. Seen Nichicon and Rubycons with "Y" vents instead of their respective "X" and "K" vents. Often harder to tell especially with fake Nichicons unless you pull them out to look at the seal on the bottom. For fake Rubycons, they often have the "K" vents but the bottom seal plus a slight printing or spelling change always gives them away. Also the colors are dead giveaway if you are familiar with original colors used for that particular brand and series. Their sizes also somtimes does not conform to datasheet.
                And believe it or not, there also fake/counterfeits of capacitor brands like CapXon, Ltec and MaxCap.
                Very often these fakes measure fine on capacitance, but the ESR is different from the datasheet specifications. Lifetime unknown, possibly standard capacitor lifetime of 1000 to 2000 hours...
                • PeteS in CA
                  • Aug 2005
                  • 3580
                  • USA, Unsure of Planet
                  Some counterfeiters/rebranders are less incompetent than others. Several years ago I was asked by my company's purchasing people to check out some "UCC LXZ" caps, because they were not from an authorized distie. I didn't even have to open the sealed bag or examine them closely to see they were fake. The PVC/PET sleeve was black rather than UCC brown. The font and information format was also wrong. But counterfeiters/rebranders can't be relied on to be that stupid. At the same company we were asked, in a similar circumstance, to test some ST Micro MOSFETs. They looked OK, but one of our tests revealed they were not genuine. What the MOSFETs actually were was an older (and more common), somewhat lower performance IR part. The rebrander had bought a batch of surplus decent IR parts and done the fakery quite well. If we hadn't tested them they probably would have been used and "only" had a higher than normal failure rate.
                  PeteS in CA
                  • ShontelleE
                    Banned
                    • Apr 2014
                    Are you aware that counterfeiting takes billions a year away from legitimate, authorized vendors? It's sad to think that a lot of retailers involve in this criminal industry. I know that fake products are cheaper, however, the qualities are not good as the original ones. I personally believe that I can save more money if I'll buy branded items.
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Yes I am!
                      Crazy, isn't it?!
                      Even then... like whirlpool dishwashers, they are CRAP.
                      Muh-soggy-knee
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Take your spam away from here!!
                        • Ed Herdman
                          • Apr 2014
                          • 31
                          Hey, my last one survived 11 years. The new one seems pretty good, though we'll see.
                          • Olkus
                            Elna capacitors - fake?
                            by Olkus
                            I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
                            09-01-2023, 02:45 AM
                          • dragon3x
                            by dragon3x
                            power on.
                            Here are some examples :
                            switching supply area).
                            than 6.3 V.)
                            03-21-2025, 02:46 PM
                          • slybunda
                            AA and AAA battery charger capacitors?
                            by slybunda
                            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                            it has inside:
                            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                            2 x 470uf 16v LZ105c branded as G.Luxon
                            not heard of these brands are they any good?
                            iv attached photos of the charger and the board inside for an idea on the type of...
                            12-24-2023, 04:41 AM
                          • Hitto
                            Fake Nichicon capacitors with almost-perfect sleeve?
                            by Hitto
                            Fake Nichicon capacitors with an almost-perfect sleeve?
                            Same font, perfect logo, same size of the sleeve. The air vent looks okay. The diameter of the capacitors is correct per datasheet.
                            It truly looks like the real thing.
                            I doubt that you would distinguish it from a genuine one.. if it wasn't for the bung.
                            Shall we be afraid, at this point, that even the bung can be replicated?...
                            01-09-2021, 03:07 PM
                            After all of...
                            07-13-2024, 08:14 PM
