I'm replacing some caps on a pc motherboard. I have done so mannnyyy times before but just wanted to ask how important is it to use the exact same size caps as te originals, until now I replace the same spec and size but just wondered if it matters too much. Also can I replace bad caps with the newer solid state type aslong as the specs are the same?
