If they measured the spacing between the 'so-called' legs, being the terminals (or leads) , they would call that the 'pitch' of that 'leaded' component (part) ...
In my previous post I specifically named the diameter of the caps (10 mm); that was of course the outside case diameter of this cylindrical component ! (a diameter couldn't be the space between the leads, nor could it - in this case - be the diameter of those leads themselves)
Just keep the basic static stuff rules on and on/of the soldering iron farer away from mosfets and you will be fine.
