THANKS!! and an oooooops!
  • glutton4punishment
    • May 2013
    • 81
    Somehow 2 lcd's recently fell into my possession. Replaced bad caps (even ones that looked just a bit rounded on top), and voila!, 2 working lcd's!!
    I took apart an old laptop...and found a SMD cap that had separated one leg from the board. I bought a electrolytic of the same value and spent a few hours in hell trying to tie into the spots on the board where the old SMD had been. I had to scrape off the green top to make a strip to solder the new cap. WHEW!!
    The funny part is after I put it back together and it still didn't work, I decided to "bake" the MB in a toaster oven. I set the temp at around 375, set the MB in there and went to look for something on the web as I waited for the oven to heat up.
    My wife calls out to me that the oven smells funny. I run over there and find a well done MB! I had my IR thermometer at hand to monitor the oven temp. It was well over 500. DAMN! the oven had warmed up much faster than I expected...
    On the floor of the oven were various parts of the the MB that had exploded off the board (the electrolytic caps), other parts that had melted loose of the board and had slid off or had just shifted a few centimeters off their original position.
    so the lessons I learned were:
    1. check oven temp before you put in the MB for a reflow
    2, when you fashion the aluminum foil "legs" for the MB, make sure the MB is dead flat when you put it in.
    3. learn when to call it quits.
  • dj_ricoh
    • 2073
    • uk
    Re: THANKS!! and an oooooops!
    My first ups was with a pc motherboard and did not know that the caps will get bigger :O
    • tmcw
      Drying Oven - Preset Temp Fail
      by tmcw
      Here's an unusual one...
      This is a Gallenkamp oven, used in a laboratory space, goes up to 220 Celcius, but is usually maintained at about 115 Celcius. Used for drying glassware, molecular sieves, and so on. Oven is in excess of 20 years old.
      It heats up fine, there is an orange light on the front that indicates that the unit is heating, and when it reaches the preset temp, the orange light goes out. All good so far.
      However, after the preset temp is reached, the temperature continues to rise, power to the heating elements isn't cut off.
      01-21-2021, 03:11 AM
    • Fsufan1391
      LG Oven model LREL6325F
      by Fsufan1391
      Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
      04-23-2025, 05:42 AM
    • schnauzer2021
      Chasis bond to neutral to overcome oven tripping problem
      by schnauzer2021
      I have a 6 years old Rowenta table top oven. The oven have both convection and grill function.
      Last Christmas I used it to roast a turkey with the convection mode for about 4 hours without any problem. When I switched to grill mode to deep browning the turkey for the final half hour, the power trips after a while.
      I have not been using the oven since then. Last week, when I try to use the oven again, both convection and grill mode trip the power supply a few minutes after turning it on.
      As I was too busy with my work, I leave it to the repairman...
      09-13-2021, 02:40 AM
    • bpjl
      SEF 551.10 - Error starting the reflow oven.
      by bpjl
      When starting the SEF 551.10 reflow oven, the following problem occurs:
      It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
      PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
      10-17-2024, 06:30 AM
    • ronaldopdias
      14" MacBook LCDs - has Apple re-introduced a new serialisation type?
      by ronaldopdias
      Since about a month or two ago, we've observed a new type of 'serialisation' on the LCDs and we're just curious whether anyone has seen this
      • New LCDs straight from the factory (not programmed)- if the Mac is restarted or switched on from a cold boot, you must close the lid, then open it again (so two cycles of opening and closing the screen) in order to get display.
      • Transplant the IC onto another screen:
        • If the model and revision match exactly then it will perform as normal
        • If the manufacturer matches exactly BUT its a different revision, the colours are mostly in
      06-28-2025, 09:56 AM
