Capacitor Question
  • 1supertech
    • Apr 2012
    • 384
    Capacitor Question
    I buy non working monitors to repair and sell them. I have noticed that a seven year old monitor that have low ESR value on Capxcon, Suscon, Lelon and most of the caps that are listed on Badcap .com.
    Should I trust those capacitors that look and test fine or should I just replace all caps? I have been doing this for about a year and so far I have a good track record with no monitor returns.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Capacitor Question
    Since you live in the USA, you have access to high quality capacitors from reputable distributors for relatively little cost (especially if you buy in quantities of 10 or 50).
    With that in mind, I saw this quote recently ...
    “It takes many good deeds to build a good reputation, and only one bad one to lose it.”
    ― Benjamin Franklin
    --- begin sig file ---
    --- end sig file ---
    • 1supertech
      • Apr 2012
      • 384
      Thanks retiredcaps I will change them all
      • retiredcaps
        • Apr 2010
        • 9271
        And to drive home the point, see this recent complaint
        https://www.badcaps.net/forum/showthread.php?t=28449
        • 1supertech
          • Apr 2012
          • 384
          I guess I have been lucky on no returned monitors just changing bad capcitors using
          Panasonic caps fm,fr,fc. Looks like I better change them all good or bad
          Thanks retirecaps
          • retiredcaps
            • Apr 2010
            • 9271
            I save the non bloated bad quality name caps for uncertain projects or as "test" caps.
            • 1supertech
              • Apr 2012
              • 384
              Good Idea
              • MORETTIGIAN
                by MORETTIGIAN
                Title:
                Description:
                Procedure performed:
                - Removed backplate
                - Reapplied thermal compound
                - Reassembled card
                09-18-2025, 12:14 PM
              • keepread
                Dell monitor PSU vs Dell laptop PSU
                by keepread
                Hi there!
                Someone gave me their old monitor, it's Dell S2715ht.
                The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                10-30-2025, 04:45 PM
              • tony359
                Bipolar capacitor for vintage Apple CRT monitor
                by tony359
                Good day all,
                I have a question about some old monochrome Apple monitors.
                Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
                A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
                The new capacitor:...
                08-12-2024, 03:27 AM
              • wattage
                by wattage
                Hello Badcaps Community,
                07-13-2025, 04:41 PM
              • ant3202
                HP 27es - LED monitor - Monitor Flashing On - Off
                by ant3202
                Hi Everyone
                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                https://www.badcaps.net/forum/troubl...lashing-on-off
                The monitor is HP 27es LED Monitor
                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                The monitor will randomly blackout and display no signal and will recover again.
                Sometimes need to power and off again to restore the display but...
                03-20-2025, 07:30 PM
