Best mark/type...of electrotytic capacitors
  • Ahakim
    • Apr 2013
    • 64
    Haven't you noticed recently that some (in fact many) types of relatively cheap electrolytic CAPS fail after no longer than a few months??.. Specially those of east asian origin...I start to become sick of returning repaired LCD/LED TVC's for the same symptoms and reasons: same failure of same caps in the SMPS area!! Very short lifetime...Even higher than required voltage / temperature rating doesn't help much!
    The question I ask is: where does the real manufacturing deficiency or problem reside in their fabrication ? The chemical/dielectric procuct inside these capacitors or what, exactly?
    The other quest is: What is your advice regarding the choice of good/better/ best longlife caps?
    I'm ready to pay 10$ for just ONE 470 or 1000 micofarad/50 or 63v if I know that its life time is a garanteed "more than 5 or 10 years" period (in normal working conditions). I know It's worth it, very simply because my client will get full satisfaction and he/she may come back for repair but NOT for the SAME problem!
    TH....HANKS
  • tw2005
    • Oct 2011
    • 6458
    Re: Best mark/type...of electrotytic capacitors
    Rubycon ZLJ perhaps
    http://www.digikey.com/product-detai...430-ND/3134386
    Panasonic uses Rubycon and the rest of the TV usually dies before they do.
    The ECU in my car has Rubycons in it and it's 19yo and still going.
    • retiredcaps
      • Apr 2010
      • 9271
      Re: Best mark/type/name...of electrotytic capacitors inquiry
      What are you using for replacement caps (what brand and series) and where are you buying them from?
      Since you live in the USA, you have access to high quality caps from reputable distributors like digikey, mouser, etc.
      With digikey, you can get high quality Japanese (Panasonic, Nichicon, Rubycon, United Chemi-con) made low ESR caps at a competitive rate with typically $3 USD shipping within 2 to 3 days.
      95%+ of the caps sold on ebay are either the worst possible quality or counterfeits.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        There is no need to jump to 50V or 63V for a 470uF or 1000uF cap.
        Just use quality caps like Panasonic FM/FR series in their "normal" voltage. For example, if the original cap was 1000uF 16V, get a Panasonic FR in 1000uF 16V.
        http://www.digikey.com/product-detai...398-ND/2433532
        • retiredcaps
          • Apr 2010
          • 9271
          Also, if you are professional repair person, get an ESR meter.
          • Ahakim
            • Apr 2013
            • 64
            I mostly used to use capxon or nichicon caps(availability). ESR measures are generally good before first use...They "bulge" after a few months!...
            Many thanks...
            • cashkennedy
              • Aug 2011
              • 668
              capxon is the worst brand to have ever existed, if you get 2 years out of those you are lucky.
              Panasonic / nichicon / rubycon are 200x better then capxon, and if properly selected (right capacitance / series / voltage) will last more then 10 years in anything
              Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
              • retiredcaps
                • Apr 2010
                • 9271
                Capxon makes terrible terrible terrible quality caps.
                Now you know better. There is no excuse not to get Panasonic FC/FM/FR from reputable USA based distributors for your next projects.
                Budm has used thousands of them over several years with lots of success.
                https://www.badcaps.net/forum/showpo...5&postcount=20
                • Ahakim
                  • Apr 2013
                  • 64
                  Good helpful advice...I got it! Thanks a lot.
                  Bye bye "Mr" Capxon!
                  • japlytic
                    • Oct 2005
                    • 2086
                    I prefer Chemi-Con KMQ (radial 160-450V and all snap-in voltages) and for low-ESR units, Chemi-Con KY (as my avatar shows at the time of posting) and KZM (or KZN if I can get them).
                    All of my electrolytic capacitor substitutions specify Chemi-Con units.
                    • dragon3x
                      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                      by dragon3x
                      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                      power on.
                      Here are some examples :
                      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                      switching supply area).
                      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                      than 6.3 V.)
                      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                      I replaced capacitors with aluminum-polymer.
                      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                      03-21-2025, 02:46 PM
                    • slybunda
                      AA and AAA battery charger capacitors?
                      by slybunda
                      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                      it has inside:
                      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                      2 x 470uf 16v LZ105c branded as G.Luxon
                      not heard of these brands are they any good?
                      iv attached photos of the charger and the board inside for an idea on the type of...
                      12-24-2023, 04:41 AM
                      Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                      by sam_sam_sam
                      I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                      This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                      After all of...
                      07-13-2024, 08:14 PM
                    • Cama
                      Solar Inverter - SMH-II - 2 missing capacitors
                      by Cama
                      I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                      My model is : EASUN SMH-II 7 KW
                      Mother Board : P/N 18947-002401250250
                      Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                      Thank you...
                      09-12-2025, 02:50 AM
                    • Ady2017
                      Are there any datasheets available for Elna RJG capacitors?
                      by Ady2017
                      I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                      05-25-2025, 02:19 PM
