Should these piezo cap sensors be replaced?
  • gomavs123
    • Apr 2013
    Hello all, first time poster.
    I have a set of 10 piezoelectric sensors that I measured before going through with a test. Usually, when measuring the capacitance I get around 3nF. However, I noticed that for about 30% of them that I had (~3 out of 10 that I had), the capacitance meter, will spike up to a value much higher, like 100nF or so and keep on ramping down to about 15nF or so. It will slowly retreat down, but to about 5nF or so. Some of them will just go up to 10 nF and go back down, but one way or the other won't reach the value of 2.
    Usually when the capacitor is bad, or broken, this particular type of capacitive sensor gave a very low value, such as .167nF or so. However, these are not doing that.
    I tried it with a different capacitance meter (different brand), and noticed this same issue with this particular batch.
    What is the explanation of this? Should I replace them? Have you guys seen this pattern for regular caps before?
    Thanks in advance for your help.
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Should these piezo cap sensors be replaced?
    High leakage current (partial short) can confuse a cap meter like that.
    • harp
      piezo worn out issue
      by harp
      I wonder if it is real, or missleading some other problem? ?............... https://m.youtube.com/watch?v=ceb09rxPohA ?....... in video is presented claims that new piezo fix problem of poor production of moist, what is electronic science stand behind that conclusion? Can piezo be worn out and hot to tested it for that condition.............. in the past I see video where is piezo torturing through test vith high voltage, various frequency, and it is amazing what can survive and operate after damaged.
      10-13-2024, 03:40 PM
    • MicroSMD Lab
      MSI MS-16W1 no power, EC replaced by other.
      by MicroSMD Lab
      Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
      03-27-2025, 07:35 AM
    • RetroComputingGrotto
      IBM LTO 7 Tape Drive - Dust Sensors??
      by RetroComputingGrotto
      I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
      I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
      09-19-2024, 01:54 AM
    • thesame
      Asus FX505DD REV 2.0 no power after someone replaced the cmos battery with a screwdriver.
      by thesame
      I have a dead FX505D, motherboard FX505DD REV 2.0 , the owner replaced the cmos using a screwdriver and he touched something on the board, since then the laptop its not starting, i have managed to see that U8800 (BQ24780SRUYR) charging IC is getting hot under a thermal camera , i have desoldered it but the laptop still doesn't power on, i also have no voltage at power connector on the board. I also replaced the U8800 but still no power. What should i check next?
      04-22-2024, 01:21 AM
    • zlr8r
      HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
      by zlr8r
      Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
      To begin with, this laptop was dead-dead.
      Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
      • am getting white power led
      • 5-long-flashes on CAPS Lock and NUM lock
      • then, fan full speed
      • CPU heats up some (smaller die PCH, does not)
      • always constant black screen no matter what's tried
      • no USB recognition
      • no HDMI output
      this is as far as I can get with it and not sure where to inspect next ?
      I tried...
      03-27-2024, 03:13 PM
