Bad cap no markings
  • greenhorn
    • Feb 2013
    • 8
    Bad cap no markings
    I am working on a 20" Westinghouse LCD TV. The power supply board is what I am attempting to repair. So far I found 2 X2 film caps blown and changed them. Before I changed them I would turn on power and it would go off immediately after and that is why I started with this board. The Tv turns on with red light then blinks to green back to red but it stays on now. It appears that I have no power going to the LCD screen itself because I have no backlighting and no picture. I have searched for a schematic for this board but could not find one.
    I have no clue as to the replacement cap shown in the photo. It is a PCB4612AC P/N 3BS00908 The board is marked C6 and C7 where these 2 caps I removed and tested to be bad. I found a crack in one of these so I removed them both and both tested bad. The cracked one fell apart getting it out. There are no markings just the color blue. Any help figuring out what part I need is highly appreciated! WAIT before I posted this I looked again at the cap that did not fall apart and found a marking F .27J PMD 250V So now we know more already and I have not hit reply yet. Where can I purchase this cap is now the 64 dollar question. Tried digikey and mouser so far no luck with google yet. Suitable sub maybe? Thanks for any help!
  • greenhorn
    • Feb 2013
    • 8
    Re: Bad cap no markings
    Would this work as sub?
    http://www.ebay.com/itm/10PCS-CBB-27...-/200773856296
    Or
    http://www.mantech.co.za/ProductInfo.aspx?Item=14M4418
    • japlytic
      • Oct 2005
      • 2086
      Welcome, greenhorn!
      They appear to be polyester 0.27uF 250V units on the secondary side, but not X2 class.
      • greenhorn
        • Feb 2013
        • 8
        Thank you for the reply japlytic......... Went to website of Nippon and searched for spec caps but no results. I am just not sure what I can use as suitable sub for this particular cap. A appreciate your input regardless. The 2 yellow boxed film caps are the 2 X2 class I changed already as they were swollen and blown when tested off board.
        • selldoor
          Slow Learner
          • 7870
          Are you sure digikey dont have any?
          Is this one? There are others similar - diff physical sizes.
          http://www.digikey.com/product-detai...0972-ND/295879
          Or This
          http://www.digikey.com/product-searc...274-ND&stock=1
          • greenhorn
            • Feb 2013
            • 8
            Selldoor it appears the first link is a good sub. Thank you
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
