Looks like red-striped FZs exist too!
  • RJARRRPCGP
    • Jul 2004
    • 6304
    FZs with red stripes!
    http://dx.com/p/fx5500-nvidia-nv34-0...cs-card-174341
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • lti
    • May 2011
    • 2548
    Re: Looks like red-striped FZs exist too!
    No vents...
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      more bang for the buck!
      Originally posted by lti
      No vents...
      • Rulycat
        • Apr 2010
        • 724
        Even worse, an FX 5500 in 2013!
        • c_hegge
          • Sep 2009
          • 5219
          I've seen vent-less Sacon FZs before. After re-capping the card they were on, I reverse-polarised them, and they went kaboom.
          • Petros_Z
            Led stripes for Toshiba TV 32W1433DG
            by Petros_Z
            Hello, I have the TV of the title and it has problem with the led stripes. The code of the stripes is VES315WNDA-01. Also on the chassis there is a code "Model VES315WNDS-01". Searching for spare parts I found that there are led stripes for each of those codes. I don't know if someone had changed them before. Based on what code should I order the spare parts? From led stripes or chassis?
            Thanks in advance and sorry for my bad English.
            04-02-2024, 02:59 AM
          • kotel studios
            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
            by kotel studios
            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
            08-06-2025, 02:07 AM
          • halen
            Hisense H55U7B vertical stripes
            by halen
            I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
            1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
            2. Connected only left side of LCD to tcon, big stripes
            3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
            Where could be problem?
            Tcon RSAG7.820.7932/ROH
            Main board RSAG7.820.8698/ROH
            Jan
            06-18-2025, 03:58 AM
          • korsar86
            Sharp LC-65CUG8052E stripes on the display
            by korsar86
            Hey, everybody.I'm asking for your help. Brought this TV in to replace the backlight. After replacing the backlight there are such stripes (see photo).
            The glass is not broken, decoders are intact, everything was done very carefully and in antistatic gloves. The experience of disassembling such diagonals is great. I do not understand what is the reason for such stripes that appear a couple seconds after turning on.
            Loops rewired, wiped them with alcohol, the connectors are clean. Who by experience can tell me why this happened? Perhaps at the reception did not notice when shining the...
            04-23-2024, 12:29 AM
          • ahoonid
            MacBook A1990 vertical stripes on external screen
            by ahoonid
            Hey everyone,
            I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
            The board is neat. Not opened before for sure. Just a little dust, nothing more.
            Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
            06-20-2025, 08:54 AM
