Sound problems, a sign of bad caps?
  • KILLorBE
    • May 2004
    I'll try to keep it short.
    My Asus P3V4X makes strange popping/clicking noises when playing MP3's, also when I run F@H it doesn't finish a single WU (It keeps saying Early unit end).
    But when I play a WAV file I don't hear strange noises.
    I've replaced everything (RAM, PSU, Mouse, Keyboard, CPU, Sound card, IDE cable, HDD, Graphics card) except the MOBO (doh) and 2 NIC's.
    I also did a fresh install.
    First thing that came to mind was a power issue, but I don't want to buy caps if I'm not sure (the caps look fine).
    The MOBO is 3+ years old and has Sanyo Gold on green 1500uF 6.3V caps, and a few Silver on green Sanyo caps.
    Suggestions are welcome.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    I doubt caps are your problem. Sanyo caps are not prone to failure. If it was a cap problem, the audio would do it all the time, and there would be other serious issues with the system. Experience tells me this is a driver issue. I had an SB Live do that very thing to me in a VP6. I played around with different driver packages, and eventually fixed it using the embedded driver in XP.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • stretch0069
      Screwed Up Super Moderator
      • Oct 2003
      • 2662
      • oooo ess aaaaaaaaa
      How long can you play music until the popping and clicking...or does it do it as soon as you play?
      Way back when I was having probs with my VP6, this happened to me...among other annoying things. A lot of things cleared up when I replaced the caps and got a proper PS.
      "Its all about the boom....."
      Guns kill people like spoons made Rosie O'Donnell fat.
      We now return you to your regularly scheduled drinking.
      "Fear accompanies the possibility of death.....calm shepherds its certainty"
      Originally posted by Topcat
      AWD is just training wheels for RWD.
      • KILLorBE
        • May 2004
        Thanks for the replies.
        The problem is solved, not sure what it was (yet) as I've changed 3 things:
        1) Swapped the V3800 Ultra Deluxe (which doesn't like Ali chipsets, maybe it doesn't like VIA chipsets either) for a GF2 MX.
        2) Went from ME to W2K (After all those years installing ME became a ritual and I never had this problem before).
        3) One of the IDE connector pins on my DVD-Rom was bent, maybe it corrupted the install.
