Re-capping went.. well? Impossible! :P
  • mikebdub
    • Oct 2012
    • 5
    I re-capped my Dell Inspiron 9200 today and it went 'OK' I guess.. I had no problems getting the old ones out, but I did have a bit of a time with clearing the holes. I have soldered before, but not very much so I was not expecting the computer to even work by the time I was done! Got the new caps in even though my soldering was not the most beautiful but she booted right up! I really have no faith in my soldering abilities, but something must have gone right or I am pretty sure she would not have even started up. I have been running Prime95 for 2 hours now and all seems well.. Are there any ways to 'test' my soldering connections on the caps while they are on the board?
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    Re: Re-capping went.. well? Impossible! :P
    Congratulations on getting your computer working again. It takes a lot of effort to replace MB capacitors it can be very discouraging if it fails to work. There may be others that can give you better advice than mine however I will give you my 2 cents. If you gently try to rock the capacitor with the tip of your finger it should firmly resist movement. When you are doing this you should observe the leads where you soldered them and you should not see any movement. On my first few attempts I would get the capacitor leads hot enough for the solder to bond to them but not the motherboard because it was not hot enough. The result looked like a lollypop, in other words a ball of solder on a stick.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5111
      • New Zealand
      Upload a photo of your soldering, it should be obvious how good they connections are
      -David VanHorn
      • jm1234
        Soldering tips N9-XXX for ZD-8916
        by jm1234
        I have soldering station ZD-8916 and I only see like 6 different soldering tips being offered, eg. by tme: https://www.tme.eu/ie/en/details/zd-...er-peak/n9-26/
        Very limited variety, I'm missing a chisel ones, it just doesn't exist.
        I thought to myself everything is available in china, but they don't seem to be using the same nomenclature. Searching in aliexpress or temu for N9 tip doesn't find anything.
        Is there perhaps equivalent type to N9 I should be searching for?
        Or is my soldering station that weird and I just shot myself into a foot?...
        12-02-2025, 05:45 AM
      • Ady2017
        SMD fuse soldering advice please
        by Ady2017
        Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
        11-07-2025, 12:03 PM
      • Azurain
        Elitebook 840 G5 Bios Chip Soldering Question
        by Azurain
        I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
        Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
        04-14-2023, 06:58 PM
      • Peter_1402
        Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
        by Peter_1402
        Hi Everyone,
        I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
        1. Soldering iron works great
        2. There is a burnt mark on the hot air gun handle.
        I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
        Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
        Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
        Reed switch tested ok with a magnet.
        From the above test, I can conclude...
        07-12-2025, 11:50 AM
      • bpjl
        SEF 551.10 - How to raise the temperature of the unleaded soldering furnace?
        by bpjl
        We continue to struggle with the SEF 551.10 reflow oven. After we managed to start it in october - the topic here -> https://www.badcaps.net/forum/troubl...he-reflow-oven everything promised to be good. But...
        While soldering with lead paste somehow goes, but we cannot force the stove to raise the temperature
        that he would dissolve the unleaded binder. I even doubted what this bastard shows on screen and passed through it a thermocouple...
        03-16-2025, 09:26 AM
