Need help! Parallel Cap...
  • kids
    • Oct 2005
    • 13
    I'm repairing mainboard with bad PS/2 ports. I try to replace a parallel cap (near PS/2 ports ). Cap sign C221, please tell me that is C-apcitor 221-22x10^1=220 picofara, is that ?
    And I dont find any the same Cap with 221, just only C181. So can I replace C221 with C181?
    Thanks.
  • Rainbow
    • Aug 2005
    • 1371
    Re: Need help! Parallel Cap...
    If it's shorted, remove it and test without it. It should work. If it does not work, something other is bad too (probably super i/o chip). If it works, use that C181.
    • gg1978
      • Dec 2004
      • 431
      C221 is just the parts designator of the part.. it does not mean 220uF or pF.. And do not replace C221 with C181... Is this a small SMT type capacitor, or a radial leaded electrolytic??
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        good point. just show some pics so everyone is not confused...
        • Rainbow
          • Aug 2005
          • 1371
          I guess it's small SMD 4 capacitor array in 1 (like the resistor arrays). It's present on some boards near the PS/2 ports - and its 4 capacitors are connected between the 4 PS/2 lines (mouse clock and data and keyboard clock and data) and GND. I've seen it bad once, resulting in non-working PS/2 ports.
          • kids
            • Oct 2005
            • 13
            You are right! Some (or almost) mainboard use single cap for 4 PS/2 lines, we can replace each cap if it go bad. But with SMD 4 capacitor array - as you type - we must to replace if only 1 of 4 is bad.
            But I cant find any other C221, but in my hand, I just have C181. I can not replace each other, can I? So bad!
            • gg1978
              • Dec 2004
              • 431
              Ok, this is making a bit more sense now.. Chances are you can try unsoldering the part, and seeing if it'll work without it.. You may try plugging your PS/2 keyboard into the PS/2 mouse ports, as some boards allow you to do this (intel OEM motherboards especially).. If not, buy a scrap board to steal the part from.. There's a forum here where people see if others have parts they want..
              Also, this cap array is probably protecting both the ports in the PS/2 connector, as each PS/2 only has two data lines..
              What kind of motherboard is this??
              • kids
                • Oct 2005
                • 13
                My board is MSI (MS5187 VER:1).
                But I want to know I can replace C221 with C181, yes or no.
                • gg1978
                  • Dec 2004
                  • 431
                  I suppose you can certainly try it.. You do run the risk of damaging the board more from improperly soldering SMT devices.. I'd highly recommend practicing removing and replacing SMT parts on a scrap board before you try to swap the cap arrays on the 5187..
                  Chances are that you will end up disabling some other part of the motherboard by stealing C181 and placing it in C221's position.. Cap arrays can have the internal caps wired up in different ways, either straight thru, or in a bus configuration, or a mix..
                  • kids
                    • Oct 2005
                    • 13
                    Keep peace your mind! I replaced array cap and array resistor for many times. But this time I cant find any other C221. Which array cap I can replace same with C221?
                    • chth96
                      Is it no harm to replace with capacitor without ripple current rating?
                      by chth96
                      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                      Rubycon YK DataSheet (b...
                      04-19-2024, 05:19 AM
                    • RetroComputingGrotto
                      Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                      by RetroComputingGrotto
                      I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                      As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                      What is your advice/opinion on whether or not on old(er)...
                      04-03-2024, 08:30 AM
                    • chth96
                      Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                      by chth96
                      I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                      Since then, This AC/DC adaptor have been out of order.
                      But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                      After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                      And Is there any possibility that it will suddenly explode as well as to be out...
                      12-03-2023, 04:40 AM
                    • psyduck
                      Conformal coating on Samsung U32D970 monitor PSU, do I need to replace after repair?
                      by psyduck
                      I have a Samsung U32D970 monitor from 2015 I pulled out of the bad hardware pile that turned on and then turned itself back off after a few minutes of use and refused to turn back on. The PSU has part number BN44-00786A, and I found a couple posts about one that had blown with damage to the MOSFETs and PWM controller - but nothing about intermittent failures. I started a new thread and said that I would refresh the solder joints on the board to see if it was just a bad connection and possibly replace the PWM and PFC ICs. I then asked what my next course of action would be after those steps. I...
                      11-27-2023, 06:56 PM
                    • disorder
                      HP 2311 display, 3.3v regulator fried, need help to replace
                      by disorder
                      hello,
                      i have a hp display 2311 to repair, totaly dead
                      on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                      i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                      thank you
                      Today, 04:34 AM
