Genuine Nichis?
    Genuine Nichis?
    http://www.ebay.com/itm/271078054083...84.m1439.l2649
    From another badcapper.
    I noticed the series looks like "PR" from the auction. Can't find anything on this series, so no idea if it's fake or just a custom run for a manufacturer and this is old stock. If it's a fake, it's a very good one. That's 20 caps for about $3.25, which is an excellent price, if they are genuine.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Genuine Nichis?
    I doubt they are. Typical ebay fakes and junk. look at the date codes on top of all that. Never heard of, nor could I find any data on PR series. fakes.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • retiredcaps
      • Apr 2010
      • 9271
      Re: Genuine Nichis?
      Could be old stock from 2004? At least few reputable members have commented on the PR series
      https://www.badcaps.net/forum/showthread.php?t=20346
      --- begin sig file ---
      --- end sig file ---
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        Re: Genuine Nichis?
        Wrong sleeve color.
        They should be the same color as PWs- Nichicon's "Dark Brown."
        TC, they are "old school" SMPS caps. Those probably wouldn't even count as such today.
        1000u/16v, 10x20- 120 milliohm, 700 mA ripple.
        "Motherboard Low ESR CAPS CAPACITOR"- take a walk....
        Not even close to what you need in a VRM.
        We're truly spoiled with today's modern elcos.
        "pokemon go... to hell!"
        EOL it...
        All style and no substance.
        guilty,guilty,guilty,guilty!
        guilty of being cheap-made!
        • mockingbird
          • Dec 2008
          • 5484
          Re: Genuine Nichis?
          Yes, I think his stuff is legit... Looking at his other stuff, he has a lot of NOS. OTOH, his Rubys look a little weird. Somehow, I think the font on their sleeves should look more 'crisp'. Buy at your own risk.
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            Re: Genuine Nichis?
            The PR series is old, discontinued in the mid-00s, then resurrected at customer demand as the RoHS-compliant PS series. They were a very decent series back in the early 00s, but I would only use them to replace similar vintage parts or for GP applications. Assuming they are genuine, of course. And being that old, they probably should be re-formed: charged to a gradually increased voltage through a current limiting resistor (e.g. 1K).
            PeteS in CA
            • c_hegge
              • Sep 2009
              • 5219
              Re: Genuine Nichis?
              His Panny FCs don't quite look right either. He doesn't show the vent stamp or rubber seal, though, so It's hard to tell.
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • sdinelli
                latitude e5550 - no charge- all battery not recognized as genuine
                by sdinelli
                -latitude e5550 all batteries sense as non genuine(ive tried two working genuine and two new non genuine).
                -battery led flashing white and amber which indicated non genuine AC adapter. tried multiple bios.
                -ive tried multiple genuine chargers
                -the circuitry seems to be working fine and battery and charging seems to be controlled by EU2 which is ECE5048-LZY
                https://datasheet.octopart.com/ECE50...-147335658.pdf
                does this chip have to be programmed? or is it replaceable? do you all think this could be the reason?
                i have two of these same...
                11-14-2021, 09:52 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • Galraedia
                Fake Caps in Xbox 360
                by Galraedia
                I decided to take one of the Rubycon capacitors out of a phat Xbox 360 with a Zephyr motherboard and noticed that all the Rubycon capacitors near the CPU were fake. The capacitors in question are Rubycon MFZ 680uf 6.3V and they all have a bullseye bottom, something not found in genuine Rubycon capacitors. None of them were leaking, they all have the K top, and the system has never been opened before. It appears Microsoft was using fake capacitors in the Xbox 360, or the Chinese facility where the console was manufactured in was using them and passing them off a genuine. Just thought I'd share...
                02-04-2023, 09:55 PM
              • AkaBukai
                Is it okay to flash stock bios onto the motherboard's BIOS?
                by AkaBukai
                Hi there,
                I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                The little LED on the power button is flashing slowly and nothing happen.
                This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                So I decided to flash the BIOS using a cheap programmer.
                And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                I also...
                12-19-2024, 12:15 PM
