when I go to mouser.com and I go to passive components >> capacitors >> low esr there are only 2 makes: cornell and xicon. Now when I go to Low Impedance, there are nichicon and united chemi-con (both good makes). Which do I use on a motherboard?? Everywhere I read here it says low esr. I live in the US if that helps. Thanks for any help you can give.
Which caps to buy at mouser
Re: Which caps to buy at mouser
there is a list at the bottom of this thread for low esr caps suitable for motherboard applications
https://www.badcaps.net/forum/showthread.php?t=613
the ones on the right are lowest esr
you want lowest esr you can find and highest ripple. read the spec sheets and figure it out. -
Thanks willawake. Didnt realize I made a new thread. Sorry about that.Comment
On mouser.com, use low imp. instead of low esr. Nichicon p series and h series.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.-
- Loading...
