Nichicon HM/HN/HZ scheduled for discontinuation
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Nichicon HM/HN/HZ scheduled for discontinuation
    Originally posted by momaka
    I used a solder sucker/solder pump on mine and it worked just fine. Braid is not cheap so I try not to use it when the situation allows.
    If you buy it in quanities 50ft+ it's not too bad. I get mine for $20/50ft, or $.40/ft. Each LCD uses up maybe 8" on a bad day... so $0.27 per board. For me, it's well worth it.
    I have never had good luck with solder suckers other than for reducing the volume of solder on large joints. Even then, 4 out of 5 times I have to finish the joint with some braid. I wouldn't use a sucker on LCD transformer/transisitor joints anyway; that's a good way to kill the pads/traces.
    I do that all the time (wiggle it out by heating 2 pins at a time). No pliers either! Just gotta have your iron real hot so you can be real quick - that way you don't get burned. If you add some flux to joints, it can be even quicker.
    I do have to admit that I can tolerate a lot of heat on my fingers, though (I regularly clean the nozzle of my hot glue gun with my fingers). For those that can't, a piece of cloth or a pair of thin gloves would do. I have a piece of cloth on my bench when I need to remove components with all-metal cases - those do burn me eventually.
    I accidentally did that once and burnt my self in a bad way. If you can do what you say you're doing, I'd bet that your iron isn't delivering enough heat.
    sigpic
    (Insert witty quote here)
    • mockingbird
      • Dec 2008
      • 5484
      #62
      I don't want to invest in a large spool because I use the 0.5~mm for logic boards and tight spaces and the wider stuff for regular applications. So I'd have to buy two spools. The 5ft spools keep me going for a few months. You should also keep in mind that when you buy the smaller diameter stuff, the price should be less because you're getting less copper.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Yeah, smaller diameters are cheaper... what I like to use is 0.075". It seems to be a good general purpose braid size...
        My current (and the previous) braid was this:
        http://www.frys.com/product/4462116?...H:MAIN_RSLT_PG
        (and yes, it is pre-fluxed)
        One thing I have noticed is that the stuff that comes in the tinier things (like they have at radio shack) is a much crappier braid than what comes in the more traditional spools (like what I linked). It seems to be a much looser and less effective braid (often w/o flux) from my experience. The only brand where the braid type was constant was the MG chemicals brand above (their stuff isn't half bad; I am pretty fond of their 63/37 solder).
        I wonder if one could get better pricing through digikey or the like... I may try that when my current braid runs out.
        sigpic
        • mockingbird
          • Dec 2008
          • 5484
          #64
          .05 is essential for for clearing motherboard cap holes. .075 sinks away too much heat... I'd like to get my hands on some .035 and see if that is an improvement even over .050. Digikey is expensive for the 5ft spools. I don't know what kind of stock Radio Shack has but every brand I have tried has worked extremely well. I could get 5ft spools from China for less than $2, but they only have them in wide diameters and who knows what the quality is like.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            radioshack braid is unfluxed garbage. Complete ripoff.
            .75 works well for me... no heat loss issues... then again, I have a 60W iron.
            sigpic
            • mockingbird
              • Dec 2008
              • 5484
              #66
              So do I. I guess you have a fancypants iron with the expensive tips. The $6 one I got from China (Which works fantastically) has a relatively blunt tip (Thing is very durable though, I don't think I'll ever have to change it).
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Mine is a Weller W60-P that I inherited from an Estate (Long story). The tips weren't too bad ($4.70 a pop from newark). The iron't temp is regulated by a magnet (curie point) at the end of the tip. My two tip sizes are:
                1.57mm Chisel- it runs at 700C
                3.18mm Chisel- it runs at 800C
                I haven't had the iron that long (I've had it 10 months but usable for only 4) but it so far the tips have been been doing great, other than the usual color changes to the tip's non-soldered body there have been no signs of wear.
                Both tips can do the braid OK, the larger and hotter one running a lot better for obvious reasons.
                sigpic
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  The only thing I don't like about desoldering braid is that sometimes the braid lets go from the solder all of a sudden, and it flings hot solder in the air.
                  Always wear glasses/safety-glasses when soldering! Its a MUST!
                  Muh-soggy-knee
                  • c_hegge
                    • Sep 2009
                    • 5219
                    I've never worn glasses when soldering.
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      pft, Iv'e slopped solder all over myself countless times (have a few scars from that too xD)!
                      Actually, I just realized that it's been months since I last burned myself on the soldering iron, getting better at it!
                      Muh-soggy-knee
                      • y_not
                        Same 'ol Song
                        • Aug 2009
                        • 147
                        Ratdude,
                        Can I ask why it's advised to use such an eensy weensy braid size, as opposed to the bigger stuff?
                        Yeah, I stupidly bought the RatShack stuff, it was all I could get my hands on here. It left a bit to be desired, but really I think more than anything it was my iron. It definitely pulled up solder. But I wouldn't say so much that it "wicked" it. Not that I'm singing its praises or anything, but it does look pretty tightly packed, then again I have nothing to compare it to. I know I had to crunch it and spread it pretty good, like Chinese finger cuffs, to get it to spread out. Seemed to work better that way, although I have now learned it seems you aren't supposed to do that. OOPS!
                        The RatShack stuff was 8.5MM in width, which is just shy of 5x wider than what you use.
                        Being not much larger than most recommended solder sizes. Maybe 2x as wide.
                        Wouldn't you just go through the smaller stuff 5x faster, more feeding, more cutting, more frustration?
                        Please do tell, I desire to learn.
                        I have tried finding a video and searching the forums, but not much luck.
                        How to properly apply thermal grease - Y_not's way.
                        • mockingbird
                          • Dec 2008
                          • 5484
                          #72
                          When you're trying to wick lead free solder from a small circumference , narrow wick is a must. I can get away with 0.075" wick in a pinch, but it's much easier with 0.050". This is of course the case with modern motherboards.
                          If you have no wick, then you can leave what's left of the old solder in and rock the cap in while holding the iron to the pad from the other side of the board, but it's much easier if the holes are already clear and you just plop in the replacement cap and solder it in (eventhough this takes more time), and there is also much less risk of ripping off the bottom part of the pad this way.
                          • y_not
                            Same 'ol Song
                            • Aug 2009
                            • 147
                            Thanks for the answer. That makes total sense now, thanks.
                            I take it you're kinda shoving it into the molten solder down into the hole instead of on the top of the hole, flat against the board. Yeah?
                            Any 'ol brand of wick good so long as it's a major brand and is empregnated /w flux. Or is one brand/type better than another?
                            • bestsystem
                              • May 2011
                              • 59
                              #74
                              wait, I am in Tokyo Akiba now and a large electronic store is selling nichicon HZ with datecode 1606
                              • bestsystem
                                • May 2011
                                • 59
                                #75
                                the build quality, specs and size as well as the store appear to be very genuine.
                                • bestsystem
                                  • May 2011
                                  • 59
                                  #76
                                  See these pictures
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16958
                                    they're fake unless there was some small specialty run made of them. where did you get them, and lets see the bungs.
                                    <--- Badcaps.net Founder
                                    Badcaps.net Services:
                                    Motherboard Repair Services
                                    http://folding.stanford.edu/
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • bestsystem
                                      • May 2011
                                      • 59
                                      #78
                                      http://imgur.com/CFDHG9H
                                      http://imgur.com/zRSXUMs
                                      Hope the resolution is high enough
                                      • bestsystem
                                        • May 2011
                                        • 59
                                        #79
                                        They were found in Tokyo, Japan
                                        https://goo.gl/maps/euVxBfSghBK2
                                        • Topcat
                                          The Boss Stooge
                                          • Oct 2003
                                          • 16958
                                          they appear authentic, but the fakes are getting good these days. Considering Nichicon discontinued these years ago, finding them with current datecodes on them, I'd be very skeptical of their legitimacy if I wasn't getting them directly from nichicon or a very trust-worthy vendor.
                                          Team : 49813
                                          Join in!!
                                          Team Stats
                                          • DrewPhillips
                                            Capacitor Diarrhea - Nichicon PL Series
                                            by DrewPhillips
                                            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                            03-02-2025, 10:18 PM
                                          • nick3092
                                            Mid/late 80's Nichicon Yellow Caps
                                            by nick3092
                                            I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                            08-28-2022, 03:56 PM
                                          • chth96
                                            Is there datasheet for nichicon LXJ series?
                                            by chth96
                                            I want to calculate capacitor ESR referring to below guide.
                                            https://forum.digikey.com/t/calculat...-from-tan/2633
                                            I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                                            I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                                            Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                                            11-20-2022, 08:11 AM
                                          • chth96
                                            Is there any datasheet for nichicon RT(M) series?
                                            by chth96
                                            A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                                            https://www.badcaps.net/forum/troubl...e-been-blew-up
                                            and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                                            But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                                            I have spare console...
                                            11-28-2023, 03:36 AM
                                          • spiros.p
                                            EV dsp,replace the nippons lxz with nichicon fw ?
                                            by spiros.p
                                            Hi guys.I have two EV dsp processors and before two years i do full recap to both. The units have before recup thousands hours running.On output input coupling caps (16 pieces) i solder nippon lxz series 100mf 63v (this time i don't have other stock) i know is low esr caps.Last week have found and order nichicon fw standard audio series.Is a good reason to replace the nippons lxz with nichicon fw ? The units get better sound? Or get worse?Thanks for any advice.
                                            12-19-2023, 12:26 AM
