Hi. I'm like crazy thise days. Here what's coocking:
Was playing game and monitor screen got black, turn off PC by the
emergency button ...and can't turn it on agaen, just MOB light is on and
when pressing power button fans(case+CPU) moves litle bit.
First think was PSU, was going to RMA and one sec just for any case took
it off and swithed on second PC---WORKS!!!!(PSU).
Now i have the problem: what the hell is it?
Made minimal BOOT with same components-0 result.
Changed Graphic card-0.
Cahnged Memory -0.
Changed Lit.battery and reseted the MOB-0.
Changed Power BTn connection wire by another-0.
Changed CPU+FAN from working PC-0 results.
PSU i tested on second PC and works. Also tested VGA and Memory sticks-working, then i tested second PSU on thise
MOB and results are same-FANS moving litle and that's all, MOB light is on. Can't test CPU himself-(SY-P4RC350)-can't runs 3.4 GH, maybe need
BIOS update because MA site it does.
What else i can try more? (Someone sad it's BAD CAP'S problem on the MOB !!!!????)
How i need to make sure the CAP's are bad or not? It doesn't shows nothing speciphic. Maybe marks on the top? Good--"K" and bad ones-"X"?
PC: PIV 3.4 GH PRESCOT w/ZALMAN 120 mm CU fan.
Cooler Master eXTREME 6ooW PSU(under warranty)
2 GIG CORSAIR TWINS memory.(lifetime)
SOYO SYP4I865PE Plus Dragon 2 v1.0(2 years passed-build it 2 months ago)
ATI RADEON 9800 PRO
WD HDD's 40GiG+160GiG
Do you think it's BAD CAPS problem?
http://www.soyo.com.tw/products/proddesc.php?id=298
Cahnged Memory -0.
ATI RADEON 9800 PRO
