I see this a lot on PSUs that are cheap. Why do they do this? Surely 6.3V caps are enough. I am theorising that in fact they use a 10V capacitor on areas only needing a 6.3V cap to extend the life of the cap?
Why do they use a 10V cap instead of a 6.3V cap?
Re: Why do they use a 10V cap instead of a 6.3V cap?
10V caps are larger, so they have lower impedance and higher ripple current. Often economies of scale can make certain values cheaper, too. So they might use 10V caps on 3.3V as well.
Applying a voltage up to the maximum rated does not damage the capacitor, nor will it measurably shorten the life. Exceeding it, however, will damage it and shorten the life.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Could it be voltage spikes? My Powmax/Leadman PSU put out 50V pulses across some of its 1uF or 10uF 16V caps. The spikes were still pretty high after the caps were replaced.Comment
While I'm not sure where exactly those 50V pulses come from, rectified AC before filtering can have peaks I think about 1.414 times higher than the nominal voltage, and that's about 7V peak for 5V nominal, and the cap should be rated for that.Comment
^Only applies for sine waves. For SMPS, peaks can be arbitrarily high, depending on how the transformer is constructed. The positive peaks are generally the same amplitude as the output, negative can be anything.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I disagree with the power spiking theory for using 10v caps on a motherboard. Any 6.3v cap will never see more than 5v, most never see even half of 5v....so if any 5v circuit in a motherboard being spiked to the 6.3v limitation, any SCR or other IC will be instantly destroyed....forget about ever needing a 10v, if it ever spiked that much, there will be smoke! Motherboard VR's were not intended to clean up filthy power, they were intended to regulate clean power. A lot of manufacturers use whatever they sweep off the floor a lot of times when it comes to caps in hardware today (especially in the entry to mid-level grade hardware). So many over-estimate the engineering, and have no clue how much 'slop' you can get away with when recapping such devices. I could cite tons of examples of this, but I'm sure you all get the idea.
Use of 10v caps in a PSU is feasible for spikes on the 3.3v and 5v rails, but any half way decent PSU won't be spiking like that...and if a crap one is, the least of your worries would be the caps....its everything else the spiking has fried.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
How does the ESR change when you use a 10V cap instead of a 6.3V cap? Does this allow you to get away with a more "general purpose" 10V cap instead of a Low ESR 6.3V cap?Comment
Self healing applies to polypropylene caps and other similar mains rated/safety rated caps. It refers to the ability for the cap to prevent internal short circuits forming between metallised layers. AFAIK, it is "forming" for electrolytic caps. Another thing that can happen is with aging or damage to the cap, capacitance can go up, but since there's no free lunch, voltage rating falls, and this is likely to bring an increase in ESR.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Use of 10v caps in a PSU is feasible for spikes on the 3.3v and 5v rails, but any half way decent PSU won't be spiking like that...and if a crap one is, the least of your worries would be the caps....its everything else the spiking has fried.Comment
by ChaksI need help to extend the runtime of the ups board (see attached image).
This is ups board for a CM4 which has 3 18650 cells in parallel. Can I extend the 3 cells to 6 cells for a longer runtime? by soldering a wire to each of the battery terminal and connecting it to a separate battery case with 6 cells.
Thanks and kind regards,
chaksindia...-
by KYBOSHI was chatting with a TV repair shop today and the owner mentioned this but would really go into detail so i wanted to ask you guys what you thought.
He warned that a Smart TV will last longer if you use an external device to run programs (like Netflix) rather than running it natively on the TV.
Is there any truth to this and if so can someone explain the rationale? Or perhaps cite a source where I can readup on it? I havent seen anything yet.
Thank you!
by EffiSonHi. Could anyone on the forum help me find the cause of the problem?...
The board is LA-B111P Rev:1A comes from Lenovo Y50-70.
I have a identified the damaged R205 resistor, and connect a jump wire over it So it restores the backlight but causing strange problems
1. With Battery ONLY plugged in laptop works fine
2 .With Charger ONLY plugged in laptop works fine as well
3. Connecting both battery and charger at the same time shows a strange flickering screen. The flickering is not constant, it is completely random (and I think it depends on the load -
by CapLeakerI've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...11-25-2023, 10:46 AM -
by bohabohahi I have connected a Dell 2005FPW to my Dell Latitude E5400 results dell 2005 Vertical and the laptop Horizontal.The problem can not be fixed in settings I use windows 10 recently installed
what can be done to fix the problem?-
- Loading...
