Extend Dell monitors result Vertial+Horisontal
  • bohaboha
    • Nov 2012
    • 1015
    • sweden
    hi I have connected a Dell 2005FPW to my Dell Latitude E5400 results dell 2005 Vertical and the laptop Horizontal.The problem can not be fixed in settings I use windows 10 recently installed
    what can be done to fix the problem?
  • BL4K3Y
    • Apr 2020
    • 27
    • England
    Re: Extend Dell monitors result Vertial+Horisontal
    Try holding the CTRL + ALT + UP keys together to rotate the screen back to normal.
    If this doesn't work, check the graphics control panel to see if you can rotate the display from there.
    • bohaboha
      • Nov 2012
      • 1015
      • sweden
      Hi thank you no it dint work and in the graphics control panel there is no option
      to ontrole the sreen position
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Mots06
        Old Dell E5400 Laptop ( Purchased in the year 2008)
        by Mots06
        Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
        07-19-2025, 01:56 AM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
      • diamon
        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
        by diamon
        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
        Pictures of these boards:
        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
        Dell...
        02-28-2024, 12:51 PM
