MSI 694D Pro v1 (Bad Caps?)
  • kaitain
    • Jun 2006
    Hi All,
    I've had an ongoing problem with my old dual processor system (based on an MSI 694D Pro v1), causing random lockups, BSODs and mouse freezes in windows XP SP2, which prompted me to build a new dual core system (based on an MSI 945P Platinum). Now that my old machine is a spare I've been playing with Linux and Windows Vista beta 2, and have noticed something quite odd. When installing Vista it couldn't see the boot disk attached to the ATA100 controller, but linux could and suffered the standard lock ups, and disk access problems (note this isn't a harddisk issue as I've already tried a brand new XP boot disk with the same results).
    However when I moved the boot disk to the standard IDE primary connector, Windows Vista detected the drive, installed and has been working quite happily (albeit slowly) ever since, without lockups or BSODs (do they exist in Vista?).
    Question: Could badcaps cause the ATA100 promise controller (PDC20265 chipset) to go on the blink, or could the chipset have died independently, and leave the rest of the board fine? I've done a visual examination of the board and all the capacitors look fine but from what I've read that's no guarantee that they are working. Finally is it worth getting the motherboard repaired, as I was planning on putting Vista on the new system when its released and putting XP or Linux back on the old system.
    Any advice or suggestions would be appreciated.
    Ps. If its worth repairing please could someone recommend a good repairer in the UK.
    Kaitain
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: MSI 694D Pro v1 (Bad Caps?)
    Bad caps will cause your scenario, quite common. The 694D is no stranger to the bad caps plague as it is, I see them all the time for repair, and erratic ATA behavior is a classic symptom, regardless of the operating system.
    If you wish to have it repaired, PM me or KC8ADU, either of us can do it.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • kaitain
      • Jun 2006
      Thanks for the quick reply. I thought that you didn't take overseas work? What would be the cost of shipping and repair to/from the UK. Would you need the processors and memory as well, or just the board.
      Regards
      Kaitain
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        Regards
        Kaitain
        I don't normally take overseas repair, but today is your lucky day. Shoot me a PM.
        Team : 49813
        Join in!!
        Team Stats
        • welp
          PS5 Disk Tray issues.
          by welp
          I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
          Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
          Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
          So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
          With that knowledge I preceded to check all the fuses for the 12v rail on the main...
          12-19-2024, 02:04 PM
        • DynaxSC
          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
          by DynaxSC
          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
          The behaviour is also really very strange, i.e.:
          • The disk shows always up in BIOS - so it is recognized, so far so good
          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
          02-23-2025, 01:33 PM
        • madura2010
          DAY11AM6E0 hard disk drive and optical disk drive not detected
          by madura2010
          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
          i checked the connectivity of ribbon=good communication with hard and motherboard
          changed hard disk and checked=3f0 error persist
          sata power=+5v available
          Then checked data capacitors=all good
          Then checked data lines path connectivity to pch=all good
          reflashed...
          03-12-2023, 09:09 AM
        • chth96
          LG GCC-4521B cannot read any disk
          by chth96
          I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
          But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
          And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
          But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
          02-13-2024, 07:31 AM
        • Eleways
          Apple Macbook A1707 Hard disk
          by Eleways
          Hi
          I've an Apple macbook A1707 with Hdd defect.
          This product don't work with a normal Hard disk, but the hard disk it's a BGA component on the logic board.
          My question is:
          Can i exchange the hard disk, by desolder the bga Hard disk and replacing this?
          Can i replace with a different one (es 500 gb instead of 250 gb)
          This Macbook has T1 security check.
          Thanks and best regards
          Luca
          02-18-2022, 04:23 AM
