Doing a repair on an AOpen board for a client. Replacing the line of KZG 6.3V 2200uf caps along the CPU. Now I ordered a set of Nichicon HZ from here, not really thinking about size, as the spec sheet for both the HZ and the KZG list them as 10x20. However, once I got the HZs, I realized they look wider that the KZGs on the board. Sure enough the KZGs on the board are 8x20, this size is not listed at all on the KZG spec sheets I have found online. I tried to make the HZs work, but there just isn't enough room. Looking around, the only thing I could find in a 8x20 are Nichicon HM caps (and ebay is the only place I could find them for sale). So now my question is this. The HM caps are rated 16/1950. The KZG caps are rated at 13/2550, but that is for the 10x20. I would assume the 8x20 ones I have would have a higher ohm and lower ripple rating, so my thinking is the HM caps should work okay. What do some of the experts here think and does anyone have actual specs for these 8x20 KZGs?
Replacement for oddball size KZG
Re: Replacement for oddball size KZG
No.
Within a series, ESR and Ripple are related to the can size - NOT uf or volts.
The 8x20mm KZG is only .021/1870
The HM 8x20mm at .016/1950 is in fact an upgrade.
Look at -ALL- the 8x20mm or -ALL- the 10x20mm in either the HM or KZG data sheets and you'll see what I mean about can size.
.Last edited by PCBONEZ; 02-10-2012, 08:00 PM.Mann-Made Global Warming.
- Dr Seuss
lets see some pics of those, I have never seen a 2200uF 6.3v KZG 8x20....infact I haven't seen an 8mm 2200uF cap since the KA7 days......
If they are indeed 8mm, stick an 1800uF 6.3v 8x20 in there, it would work fine....and sure beat cramming the caps and lead spacing...<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
I ~think~ I've run across 2200uF 6.3v KZG 8x20mm before, but I won't swear to it.
A lot of semi-recent FSP PSUs use 8mm 2200uF 6.3v Capxon.
IIRC they are KF series and not in the data sheet.
The mentioned HM is about the only option when a 10mm won't fit. (And they often won't.)
.Last edited by PCBONEZ; 02-10-2012, 08:57 PM.Mann-Made Global Warming.
- Dr Seuss
Here's some interesting caps.Attached Filesif you find these attachements useful please consider making a small donation to the site
Are those actually legit pannies? I've seen some really good fakes... What series are they?<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
FJ data sheet shows an 8x20mm 6.3v 2200uF.
- Dr Seuss
I'll be damned....haha
The last 2200@6.3 8x20 I saw were the crappy old JPCON and Jackcon in the Abit KA7's, circa 1999 +/-....and those were garbage. They remind me of the 4700uF 10x30 fukkyou caps in so many antec PSU's that I always replaced with 3300@16 10x30....I think I've also seen those in ltec in some acbel imac psu's as well.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Do you still carry those 10mm 16V SamXon caps perfect for Antecs?^
The last 2200@6.3 8x20 I saw were the crappy old JPCON and Jackcon in the Abit KA7's, circa 1999 +/-....and those were garbage. They remind me of the 4700uF 10x30 fukkyou caps in so many antec PSU's that I always replaced with 3300@16 10x30....I think I've also seen those in ltec in some acbel imac psu's as well.Comment
Yup, sure do. I've got plenty of them.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
I've seen those in be-quiet! E5 series PSUs, which are custom made by FSP (as in made by FSP, but not quite like any of their standard series)
edit: 2200uF 6.3V 8x25 CapXon KF in a be-quiet! E5-400 PSU. needless to say they're almost always bad
That depends on what the specific cap does.
Sometimes uF matters. - And uF goes down as caps age...
You said 'by the CPU'.
If these are Vcore caps as long as the total uF is over about 5500uF you should be okay because you'd be lowering ESR too.
[And no, don't use less caps to get 5500uF. That would raise total ESR.]
.Last edited by PCBONEZ; 02-11-2012, 10:15 AM.Mann-Made Global Warming.
- Dr Seuss
Yep, thems the ones.
I did an FSP 700 watt that had 8 or 9 of them scattered through it. - PITA.
Usually there's just a few at the OP filters.
- Dr Seuss
You have 7 so 7x1800uF = 12600uF.
You'll be fine.
P4 and socket 604 & 771 & 775 etc.. only need about 5500uF in Vcore to be stable.
They end up with more uF in aid of using more caps in parallel to get ESR lower.
It's mostly about the ESR in Vcore, not the uF.
.Last edited by PCBONEZ; 02-11-2012, 10:46 AM.Mann-Made Global Warming.
- Dr Seuss
Now lets say the 3.3v rail on the board only had 2200uF caps.
Lowering them to 1800uF would shorten the time they could 'hold up' power up during a brown-out type power surge.
- Dr Seuss
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by CvradoHello my friends!
I have a question that I think you can answer and help me with!
I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
My concern is that the board won't draw enough voltage to the bac... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by the_remHello guys,
I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow... - Loading...
