I thought I had bad caps ... replaced board ... problem persists!
  • lneville
    • Jan 2012
    • 3
    I have a Dell Precision 470 - a model notorious for having unreliable caps, and about 2 years ago I had a genuine "bad caps" experience, replaced the board and all was good for a long time.
    So when recently I started getting exactly the same symptoms, I thought it must be bad caps again. The PC would reboot with no apparent cause in the Windows logs. At first the PC would be up for a whole day before restarting, but it rapidly became more frequent, and now I am lucky if it stays up for 2 mins.
    I tried vaccuming the dust off the board, reseating all memory, cards etc and even swapped the graphics card and re-did the thermal paste between the CPU and the heat sink (although the BIOS doesn't reporting a CPU temperature issue). I examined the board and didn't see any bulging or leaking caps (as I had the first time), but I went ahead and replaced the board anyway.
    I am still getting restarts though! Maybe they are less frequent than before, but still make the PC unusable.
    So what component could account for this? The only things that are the same as before the board replacement are:
    Xeon CPU
    Memory
    Power supply
    VRM
    Many thanks
  • retiredcaps
    • Apr 2010
    • 9271
    Re: I thought I had bad caps ... replaced board ... problem persists!
    Xeon CPU
    Memory
    Power supply
    VRM
    Check your power supply for bad caps. Chances are you have bloated caps causing unstable power to be sent to the motherboard.
    If you have a multimeter, it is easy to check to see if you have stable voltages.
    --- begin sig file ---
    --- end sig file ---
    • Agent24
      I see dead caps
      • Oct 2007
      • 5091
      • New Zealand
      Yeah I would say PSU too.
      -David VanHorn
      • lneville
        • Jan 2012
        • 3
        OK thanks. Getting replacement from eBay.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5091
          • New Zealand
          Replacement PSU is pointless, they all have the same problem (rubbish capacitors)
          Get new capacitors and fix the one you have.
          -David VanHorn
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            PSU or KZG or KZJ.
            Mann-Made Global Warming.
            - Dr Seuss
            • lneville
              • Jan 2012
              • 3
              Agent24 - OK I may open the PSU up and try some surgery on it.
              Is there any danger of electrocution from capacitance inside the PSU?
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                From caps, only if it's broken...
                The caps have a discharge path so unless the path is broke caps aren't a problem.
                HOWEVER:
                If it's plugged in to line power you can have almost 2x line voltage in there and on some models (probably most) the heatsinks are energized.
                - Dr Seuss
                • severach
                  • Aug 2007
                  • 1055
                  Open one up and measure the voltage of where you're thinking of touching compared to the case. The numbers should convince you how important it is to not touch. Unlike your fingers, you can attach the probes and watch the voltage change as you do various things such as turn on, turn off, and unplug to get an idea of how long it takes to become safe to touch.
                  Be sure to measure the AC and DC of the primary heat sink, the DC voltage of the large primary caps, and the DC voltage of both primary caps together.
                  sig files are for morons
                    by momaka
                    03-15-2023, 10:17 PM
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • black6host
                    Replacement caps for Samson Resolv studio monitor 65A Amp board.
                    by black6host
                    Good day!
                    I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                    I'm going to replace the caps and I'll be the first...
                    02-06-2024, 08:22 PM
                  • nd03
                    Help with Asus Zenbook UX362F repair
                    by nd03
                    Hello lads,
                    Will give a quick summary. Bought this laptop as broken. Initial board had shorted SOC (VCCGT coil shorted to GND, checked all caps and just desoldered soc to confirm, dead short from VCCGT to GND on soc). I ordered a replacement board. Board model Q326FA Rev 2.0: is: https://www.aliexpress.com/item/1005...1309180228rsDj
                    Installed the new board laptop booted but display was flickering very ugly in bios. Horizontal and vertical artifacts. I thought the GPU is dead but it turned out it was some almost broken...
                    03-08-2024, 12:39 PM
