I have a Dell Precision 470 - a model notorious for having unreliable caps, and about 2 years ago I had a genuine "bad caps" experience, replaced the board and all was good for a long time.
So when recently I started getting exactly the same symptoms, I thought it must be bad caps again. The PC would reboot with no apparent cause in the Windows logs. At first the PC would be up for a whole day before restarting, but it rapidly became more frequent, and now I am lucky if it stays up for 2 mins.
I tried vaccuming the dust off the board, reseating all memory, cards etc and even swapped the graphics card and re-did the thermal paste between the CPU and the heat sink (although the BIOS doesn't reporting a CPU temperature issue). I examined the board and didn't see any bulging or leaking caps (as I had the first time), but I went ahead and replaced the board anyway.
I am still getting restarts though! Maybe they are less frequent than before, but still make the PC unusable.
So what component could account for this? The only things that are the same as before the board replacement are:
Xeon CPU
Memory
Power supply
VRM
Many thanks
Xeon CPU
Memory
Power supply
VRM
Many thanks
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
