8600GT Capacitor
  • LoperJChris
    • Dec 2011
    8600GT Capacitor
    I've blown two caps on my 8600gt and I just need to make sure I'm purchasing the proper caps. They state on top "FZ28, 1500uF, 6.3v". I'm just not sure which ripple current, etc. to go with. If anyone could point me in the right direction I'd greatly appreciate it!
    Thank you,
    Chris
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: 8600GT Capacitor
    That's Sacon FZ.
    Bad video cards with those show up like weekly... LOL
    The specs for FZ are posted in the forum in several places.
    https://www.badcaps.net/forum/showpo...88&postcount=2
    Mann-Made Global Warming.
    - Dr Seuss
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Originally posted by PCBONEZ
      That's Sacon FZ.
      yeah, sacon fz was a popular GPU cap... just did a PCI 5500 fx 2 weeks ago with the sacons.
      sigpic
      (Insert witty quote here)
      • LoperJChris
        • Dec 2011
        Outstanding. Thanks for the assistance.
        • Prolog
          RTX 3080 FE Identifying capacitor
          by Prolog
          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
          I hope these photos make it clear which component I am referring to:
          (yes, the soldering is a bit botched from removing the blown one, I know)
          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
          12-01-2024, 08:27 PM
        • chth96
          If I replace with inferior capacitor, Is it No harm to other IC components at all?
          by chth96
          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
          I know that these capacitor will not last as long as nichicon capacitor...
          12-22-2023, 04:34 AM
        • chth96
          How can I test non-polarized capacitor?
          by chth96
          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • chth96
          Should I replace polymer capacitor?
          by chth96
          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
          Is this ESR value of polymer capacitor correct?...
          11-18-2022, 04:22 AM
