8600GT Capacitor
  • LoperJChris
    • Dec 2011
    8600GT Capacitor
    I've blown two caps on my 8600gt and I just need to make sure I'm purchasing the proper caps. They state on top "FZ28, 1500uF, 6.3v". I'm just not sure which ripple current, etc. to go with. If anyone could point me in the right direction I'd greatly appreciate it!
    Thank you,
    Chris
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: 8600GT Capacitor
    That's Sacon FZ.
    Bad video cards with those show up like weekly... LOL
    The specs for FZ are posted in the forum in several places.
    https://www.badcaps.net/forum/showpo...88&postcount=2
    Mann-Made Global Warming.
    - Dr Seuss
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Originally posted by PCBONEZ
      That's Sacon FZ.
      yeah, sacon fz was a popular GPU cap... just did a PCI 5500 fx 2 weeks ago with the sacons.
      sigpic
      (Insert witty quote here)
      • LoperJChris
        • Dec 2011
        Outstanding. Thanks for the assistance.
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
