Video - quick capacitor replacement using liquidized lead
  • retiredcaps
    • Apr 2010
    • 9271
    Just saw this youtube video where one guy replaced and recapped 12 motherboard caps in about 3 minutes.
    http://www.youtube.com/watch?v=GHeZyQ1e8i4
    Can someone explain the equipment and procedure that he is using. There is no description in his post.
    It takes me 4 minutes per cap/per hole IF I'm lucky.
    --- begin sig file ---
    --- end sig file ---
  • mariushm
    • May 2011
    • 3799
    Re: Video - quick capacitor replacement using liquidized lead
    Looks to me like a do it yourself solder pot...
    http://www.dealextreme.com/p/100w-te...den-220v-48762
    He probably uses hot air gun or gas heater to warm 60/40 solder to melting point and used that flux paste to break the surface tension...
    The leads of the new capacitors are covered in that resin and when he pushes the new capacitors inside, the solder will go up the leads by itself..
    At least that's what I think happens there.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5084
      • New Zealand
      Yeah, looks like a hot air rework station heating a small pot\tray of solder.
      Looks pretty clever, I was worried he would overheat the board but I guess it works
      Well, unless you had SMDs on the other side...
      -David VanHorn
      • mariushm
        • May 2011
        • 3799
        This looks even better...
        http://www.youtube.com/watch?annotat...7kU&feature=iv
        I wonder how hard it would be to make something like that..
        • Agent24
          I see dead caps
          • Oct 2007
          • 5084
          • New Zealand
          That's. So. Easy.
          I want that machine!
          -David VanHorn
            master hoarder
            • May 2008
            • 12175
            This guy can recap a motherboard faster than I can plug my soldering iron in the wall .
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              aww... those machines take the FUN out of recapping!
              spoiled ****s!
              sigpic
              (Insert witty quote here)
              • Agent24
                I see dead caps
                • Oct 2007
                • 5084
                • New Zealand
                Should start a project to make these...
                What would you need?
                Just some sort of table, the nozzle thing, a heater and a pump that can handle liquid lead.... Hmmm...
                -David VanHorn
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5084
                  • New Zealand
                  http://www.youtube.com/watch?v=RBeLnX7IDrY
                  This looks like the easiest way to make something like this.
                  Seems to be a block of metal with a heater inside, and a tube welded on top and filled with solder.
                  -David VanHorn
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Definitely the way to do it quickly. I like the laser pointer.
                    PlainBill
                      master hoarder
                      • May 2008
                      • 12175
                      I might try building something like is shown in the first video either this or next weekend. I doubt I'll succeed, but who knows. I got a heating element that I can probably push to 60-80W.
                      I've been removing caps from consoles and lead-free motherboards in the last few days - and it's not easy (at least not to me) even with good expensive equipment!
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5084
                        • New Zealand
                        Yeah the mini solder pot thing looks like a clever idea, cheapest certainly.
                        They sell "Cartridge Heaters" on eBay which are very cheap, and start at about 100 watts and go from there. Looks like that's what he uses actually - not sure what the hot air is for, maybe it's to assist the heater
                        I guess for the real powerful ones you'd want a control circuit of some kind as well.
                        I'm also thinking of making something myself, but a bit differently (bigger) to theirs, inspired by the idea in the attached PDF. (source: www.qrpkits.com)
                        I'm going to assume since he used Brass I can use it too.. read that plain copper would be useless as it will just dissolve into the solder (That is why iron tips are plated!)
                        Also found some unverifiable evidence online that soldering iron tips used to be brass. Anyone know anything about that?
                        -David VanHorn
                        • Evil Lurker
                          Warranty Voider
                          • Feb 2011
                          • 454
                          Personally I think some flux, braid, and possibly chipquik would work fairly well.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            I've done a credible job using a 40 watt soldering iron and a dissecting pick. On a good day with an open layout I MIGHT be able to pull one cap a minute. Adding the time to install the new caps and clean up the board the time is probably about 4 minutes a cap. I would consider this perfectly acceptable if I were recapping a board a week, or less.
                            Recently I met a gentleman who recaps Dell GX260s and GX270s. He expects to turn around a pallet of them (200 computers) in a week. I'm not sure what kind of equipment he uses, but I'm sure solder braid is not a significant part of the operation.
                            PlainBill
                            • Toasty
                              • Jul 2007
                              • 4171
                              Ungar used to make "solder pot" type tips for their irons for DIP, SIP, TO.
                              I have the DIP & SIP ones yet. But, the TO types look to be the best and cheapest for doing cap replacement. I have the heaters too!
                              Time to give it a whirl...
                              http://www.ebay.com/itm/220772421243
                              Numbers/Sizes to look for: 6943 - 0.6", 6944 - 0.5", 6945 - 0.375", 6946 - 0.280"
                              Toast
                              veritas odium parit
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5084
                                • New Zealand
                                Never knew anything like that existed as a 'proper' fitting.
                                I wonder if it would work OK for motherboards? 18 watts seems a bit on the low side, but do tell us how it goes though!
                                -David VanHorn
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  I have the 33 watt & 45 watt heaters. Should be no problem as the surface area of the solder "bubble" will compensate. These sizes would be safer, IMO, than the large puddle the first one uses. Also, probably will be easier with some boards where you have SMDs in close proximity. Like Apple iMac PSUs. OIY!!
                                  veritas odium parit
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5084
                                    • New Zealand
                                    Turns out they exist as a commercial product under the name of "Solder Fountain"
                                    They also cost quite a bit, too but I reckon you could make one for cheaper though, if you had the right tools.
                                    Came across the name from this thread: http://bbs.homeshopmachinist.net/showthread.php?t=7194
                                    Looks like brass might not be the best material for any kind of solder job either - stainless steel or cast iron seems to be a better idea, according to them...
                                    Edit: loving the operating procedure for it! http://www.circuitmedic.com/features/517.shtml
                                    -David VanHorn
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      Well, I just finished building a solder pot today. Haven't tested it completely yet though, since the clay (read: mud) hasn't dried... Yes, I did actually use mud in this project! (along with many other common materials.) I'm not sure if it will work, but we will see. The designated PSU for this is putting about 53W of power into the heating element (1.7A at 31.5V). I'm hoping that's enough given the size of this thing.
                                      If this doesn't work, I have another idea how I can build an attachment for my soldering iron.
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5084
                                        • New Zealand
                                        Sounds interesting, would love to see some photos
                                        How big is the actual pot?
                                        -David VanHorn
