Worst Caps I have ever seen: TK (Total Krap?)
  • bigbeark
    • Jan 2010
    • 661
    I decided to recap this AM2 motherboard I pulled out of a little COMPAQ box I bought as non-working. The mobo is an MCP61PM-HM.
    There are 10 1800uf 6.3v caps on this board. One is Suncon(Sanyo) the remaining 9 are TK. Three of the TK were bulging. I yanked all the TKs, then measured them with my ESR meter and Capacitance meter.
    The ESR readings varied from .08 to .012 on the non-bulged caps.
    The Capacitance readings on all the "good" ones were 85 to 100 !!
    This machine dates to 2009 I believe.
    By far the worst caps I have ever seen!
  • mockingbird
    • Dec 2008
    • 5488
    Re: Worst Caps I have ever seen: TK (Total Krap?)
    Yea, that series is equivalent to Nichicon HM IIRC or Rubycon MBZ, Suncon WG, Samxon GD.
    Toshin Kyogo. Taiwanese caps branded as Japanese. Probably OST caps under the sleeve.
    • c_hegge
      • Sep 2009
      • 5219
      No, they have a somewhat different vent to OST. I will argue to the death that they are made in Japan and are simply distributed by OST. Country of origin has absolutely nothing whatsoever to do with reliability. It just happens to be the case that most of the good brands are from Japan.
      Btw, I always say that TK stands for Terrible Kapacitor, and OST for Only Some Trash.
      • b700029
        Banned
        • Sep 2010
        • 640
        If they were rated for 250 or 500 hours at 85C, they won't last long in a hot system.
        • bigbeark
          • Jan 2010
          • 661
          Replacing the 8 TKs restored the mobo to health.
          Every other cap on the board is an OST, so there may indeed be a connection.
          So BAD that OST won't put their own name on it?
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            And the country where the Corporate Office is located has nothing to do with where their products are made.
            TK has factories in China and Taiwan since about 2002 and my guess is they've been getting electrolyte and so forth from OST.
            TK - small
            OST - big
            Mann-Made Global Warming.
            - Dr Seuss
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
