Are these good replacements?
  • algomez
    • Jan 2011
    • 17
    Visually faulty motherboard (XPC Shuttle) caps:
    1x10v 1000uf (OST, 0517, RLP, 105Celcuis)
    Replace with:
    Link1
    3x6.3v, 470uf (OST, 0445, RLS, 105Celcius)
    Replace with:
    Link2
    If you have better suggestions please enlighten me. I tried taking pics but even with macro they came out too blurry.
    I appreciate your help!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Are these good replacements?
    Your digikey links don't work.
    --- begin sig file ---
    --- end sig file ---
    • c_hegge
      • Sep 2009
      • 5219
      Use https://www.badcaps.net/store/produc...roducts_id=131 for the 1000uF caps
      and https://www.badcaps.net/store/produc...roducts_id=148 for the 470uF ones
      Those should work fine.
      • algomez
        • Jan 2011
        • 17
        Won't the 10v vs 6.3v for the 1000uf caps make a difference?
        The 6.3v vs 10v in the 470uf sound ok since 10v is higher than required...at least in my head. Also, the diameter of the 470uf should be ~4.5mm since they go in between other tight components..
        Thanks guys....I spent like 45 min in DigiKey looking for those links, duh! Sorry guys!
