Xunda caps, what is a good replacement
  • v b chil-n
    • Dec 2005
    • 32
    specs are
    Xunda TM series 330uf 50v 10x20mm ripple current 1460mA @105 deg impedance 0.050.
    I'm thinking of digikey mouser as a source so far digikey is my preference.
  • japlytic
    • Oct 2005
    • 2086
    Re: Xunda caps, what is a good replacement
    An equivalent series for Xunda TM series is Nippon Chemi-Con KZE or KZM.
    • v b chil-n
      • Dec 2005
      • 32
      Thank you for the recommendation, I have narrowed my choice to Panasonic EEU-FM1H331L and the Chemi-Con EKZE500ELL331MJ25S. which of the two is the better cap?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        For what you are replacing the Chemi-Con EKZE500ELL331MJ25S is a better choice.
        Mann-Made Global Warming.
        - Dr Seuss
        • the_rem
          Unknown transformer : how to find a good replacement part ?
          by the_rem
          Hello guys,
          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
          04-23-2025, 01:48 AM
        • rewease
          Replacement for the Siemens Bakelite caps in an early 1980s SMPS
          by rewease
          There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
          Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
          Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
          09-17-2023, 12:53 AM
        • quickname
          Cyberpower 1500AVR UPS repair
          by quickname
          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
          Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
          I decided to verify that the batteries were...
          11-12-2023, 09:57 AM
        • HectoPascal
          Replacement caps ok? (smoothing caps, PSU heating controller)
          by HectoPascal
          Hallo,
          i want to replace two smoothing caps from a heating controller PSU. They are probably 30 years old and it might be time to replace them.
          SXE 470uF 63V 105°C (tested: 472uF 0.35Ohm) --> Nichicon VY 105°C - 463uF 0.15Ohm
          SXE 470uF 25V 105°C (tested: 422uF 0.63Ohm) --> Samwha K5A 85°C - 446uF 0.10Ohm (or Panasonic RAD FC 470/25 8mm)
          I couldn't find anything about 'SXE'. That's the only declaration on the caps. Edit: The top/bottom ident says Nippon CC.
          Nichicon should be 'VY' series (linked).
          I couldn't find anything about Samwha...
          09-06-2023, 08:30 PM
        • ssl6
          MSI K7T266 Pro (Ver. 1.0)
          by ssl6
          Hey Everyone,
          Long time lurker, but I think this is my first time posting.
          Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
          I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
          11-09-2023, 01:00 PM
