Re: Intel DG965RY power on every time main AC power connected
That chip is the main I/O controller for most of the board.
Unfortunately if that is shot the board pretty much is too.
They can be replaced if you are VERY VERY good at soldering [or have the fancy expensive tools] but I think you'll find it's easier, faster, and probably less expensive to replace the board.
[Just finding a new chip can be a major project sometimes and they aren't always cheap.]
I don't even try to fix those unless I have a good replacement chip on an otherwise dead board in the scraps box.
Looks like it took a voltage spike or had an excessive current problem.
Could have been from bad caps, bad PSU, disconnecting something with power applied, or some voltage regulator chip failed.
I'm sure that's the last thing you want to hear after you have all that work into it.
Here's the data sheet for that chip.
Thank you very much for all the forum members that helped me with this
