List of Bad Polymer Caps
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    And the first contestant is; ELCON, EPL Series.
    https://www.badcaps.net/forum/showthread.php?p=160946
    They even bloat!
    https://www.badcaps.net/forum/attach...3&d=1303094863
    http://www.tw-elcon.com/en/product.php#
    Bottom of this page mentions "Samcon-Elcon"
    http://www.tw-elcon.com/en/index.php
    Which takes us here...
    http://www.samcon-hk.com/
    To see the data sheets...
    Mann-Made Global Warming.
    - Dr Seuss
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: List of Bad Polymer Caps
    it will be interesting to see what starts to show up in this thread in the future...
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      I thought polymers explode, don't bloat. Those might be lytics in a polymer casing
      • c_hegge
        • Sep 2009
        • 5219
        They bloat, then explode, whereas lytics just vent.
        Assuming the thread doesn't die before we get too many. Sticky maybe?
        I have seen pictures of Apaq polys on ASUS motherboard exploded before. I'll see if I can dig it up.
        EDIT: Not the one I was thinking of, but here's one.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I've been looking at the chemistry they use.
          Organic Polymer and [true] Solid Polymer are actually quite a bit different.
          The Organic types can form Hydrogen inside just like Lytics.
          [Which may be why some 'polymer' have vents.]
          Depending on specifics the Organics can also get pretty toxic if they overheat.
          - Dr Seuss
          • Rulycat
            • Apr 2010
            • 724
            • United Kingdom
            Do these respond to heat in the same way electrolytics do? Less heat, less chance of kaputing?
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              They even bloat!
              Yea but the owner of that card linked above said he cooked it in the oven with the caps installed so no wonder they failed...
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Oh Hell, - Delete this whole thing.
                - Or at least change the title so the title can be used for said list.
                By the time I saw photos I forgot he baked it.
                - Dr Seuss
                • Rulycat
                  • Apr 2010
                  • 724
                  • United Kingdom
                  Still would be good to keep a list of bad polymers though.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Agreed, but this doesn't go in it.
                    - Dr Seuss
                    • Perry Babin
                      How do organic polymer caps compare to liquid electrolytic for reliability
                      by Perry Babin
                      I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                      If not organic polymer, what would be the caps that could take the most abuse?
                      08-18-2025, 04:04 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
                    • Foetuss
                      Gigabyte GA-6OXT :: caps question
                      by Foetuss
                      Good evening
                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                      But I was also suprised about the bigger boys, which are 330µF 25V.
                      Could it be they used 25V caps because they were cheaper / available at that time?...
                      02-11-2025, 12:22 PM
