what caps are these, and are they crap?
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Can't find the brand here...
    Found in a Startech 250w PSU
    Ludicrous gibs!
  • tylerlough
    • Dec 2005
    • 96
    Re: what caps are these, and are they crap?
    they look like a good brand because they passed quality control
    not even worth replacing the caps because it looks like a rebadged L&C power supply
    • Mustang
      • Dec 2003
      • 203
      Those stickers are there to keep the tops from venting. It's an extra quality control measure.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i have sen a similar logo with an e in the ring of satern thing
        • tylerlough
          • Dec 2005
          • 96
          that logo with the S looks like it has a C around it, so that would make them super caps or Super crap. You pick, i'd say Super Crap because I've never heard of that PSU company
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            Startech is big in the local PC shops around here (well, PC shop, there's only one left). Their website- www.startech.com
            One that I have is just a rebranded (and not really even that) ATNG, and I'm assuming this one is too, but they removed mention of the ATNG brand...
            Ludicrous gibs!
            • Rainbow
              • Aug 2005
              • 1375
              It looks good - thick wires, good heatsinks.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                what would be the recommended series to replace caps of those type?
                would there be any benefit using low esr types?
                commonly they are rated 200v in PSUs but in Greece we have mains voltage 220-230V and in UK 240v so therefore they are slightly under-rated. would it be better to use a cap rated for higher voltage?
                If they were replaced with caps of higher capacitance, say 1500uf then would the rest of the circuit need to be upgraded also?
                • Rainbow
                  • Aug 2005
                  • 1375
                  They're rated 200V but are connected in series - so it's 400V. That's why if there's only one cap, it's rated 400V.
                  I've never replaced these primary caps in a PSU.
                  • Newbie2
                    • Sep 2005
                    • 885
                    I have seen a similar saturn logo but it was just a saturn with the normal ring around it. That was spotted in an L&C LC-B450E power supply on the two big main caps that have the normal X vent, some of the other smaller caps that have the Panasonic T vent, and the main 80MM fan of it. The fan was so weak there was only a tiny amount of air going out of the back. It was as weak as a normal 80MM fan that was only powered by 7.5V.
                    P.S. Both of those two big main caps had a QC sticker on the vent.
                    My gaming PC:
                    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                    ASUS M4A77TD AMD 770 AM3 Motherboard
                    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                    ASUS Xonar DG 5.1 Channel PCI sound card
                    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                    Antec Three Hundred Mid-Tower Case
                    Microsoft Windows 10 Pro 64-bit
                    Microsoft Windows 7 Ultimate SP1 64-bit
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      you know they are joking right?
                      • Newbie2
                        • Sep 2005
                        • 885
                        I know L&C never does QC because then how come they are so bad?
                        Deer claims on their website they have QC but it's very easy to lie.
                        My gaming PC:
                        • dood
                          Deputy dood
                          • Mar 2004
                          • 2462
                          You can do QC and still have a crappy product... as long as it's working when it leaves the plant.
                          willawake was pointing out that they were joking about the QC stickers keeping the caps from venting.
                          Ludicrous gibs!
                          • Newbie2
                            • Sep 2005
                            • 885
                            Oh, maybe the stickers are used to cover up the electrolytic crud if the caps fail.
                            My gaming PC:
                              by momaka
                              03-12-2025, 03:42 PM
                            • eryjus
                              by eryjus
                              05-10-2023, 11:21 AM
                            • Paxman_Swede
                              by Paxman_Swede
                              Hello!
                              01-14-2025, 09:51 AM
                            • captain150
                              by captain150
                              03-16-2025, 07:34 PM
                            • Foetuss
                              Gigabyte GA-6OXT :: caps question
                              by Foetuss
                              Good evening
                              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                              But I was also suprised about the bigger boys, which are 330µF 25V.
                              Could it be they used 25V caps because they were cheaper / available at that time?...
                              02-11-2025, 12:22 PM
