It's here! Wanna see dead polymer? Yeah?
  • Behemot
    • 4845
    • CZ
    Well, you won't actually see it - as long as I don't have anything which could be taken as real camera. But let's start from beginning.
    There was a great hype last year with baking video cards (yeah, I mean in oven). Basicly somebody tried to bake an old VGA to see whether there are just some broken soldering points either under/in GPU or somewhere else. Guess what, it worked than so this spread all over the world. Now some people are still triying this even if the problem is usually somewhere else (like for Radeon HDs 4xx0 - usually VRM or something dies here). But hey, you could try, it won't do any more harm.
    The problem is, there is hard solder used on all newer cards so it often dies again after time because the solder didn't melt at all, it just softened. That's the reason I'll try my HD 3870 to be just heated in oven an than I'll continue with hot air pistol (550 °C) - I am certain it could be because of broken solder points (after my Accelero lost pressure when my PC fell from bed), I was increasing it for so long that it won't boot at the end).
    Also most of the people bake the card with capacitors on - and this is one of them. So the great deal is visibly leaked Nichicon (this guy said that won't matter) and X-CON ULR's. Result is a few of them are visibly bloated, capacitance is 30-40 % lower. As for ESR, well, I used meter with scale as folows:
    0,1
    0,3
    1
    3
    10
    etc.
    It showed me 3 for all caps so I gues all of them are considered as bad now (e.g. ULR 470 uF/16 V has ESR as low as 0,011 Ω in datasheet).
    Anyay, they did not die under service, just did not handle 200 °C first and than quarter of hour at 250 °C.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5038
    • New Zealand
    Re: It's here! Wanna see dead polymer? Yeah?
    Moral of the story, if you're baking video cards, always remove the capacitors, even if polymer?
    -David VanHorn
    • mockingbird
      • Dec 2008
      • 5484
      If you go 550c, you will cause the solder to come out the sides and you will have to reball it.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5038
        • New Zealand
        I've seen a video of BGA reballing on Youtube. Doesn't look extremely hard but I guess it would be expensive.
        Flux, solder balls, stencil, knife-tip for your iron, and then some way to reflow the chip again afterwards.
        -David VanHorn
        • Scenic
          o.O
          • Sep 2007
          • 2642
          toasty Sanyo OS-CON's from a Sapphire HD3850 512MB DDR3
          bought this card as defective (random pixel-salad) on ebay.. mainly for the two-slot cooler exhausting hot air out of the case for my own HD3850, which came with the rather noisy single slot cooler.
          after i got it and removed the cooler, it became apparent that the previous idiot... pardon.. owner threw this thing into the oven to "fix" it..
          every single cap on there had popped, and the few Sanyo OS-CON's were half-molten at the bottom and had a slight bulge at the top..
          makes me wonder for how long he left it in there... and at what temp.. !?
          hard to see, but it's bulging a bit at the top. you can clearly see it and feel it in real life.
          next to a good one (right)
          • Behemot
            • 4845
            • CZ
            Exactly. I doubt some known "good" brands coudl even explode, you never know.
            mockingbird: why is it? I'll do it only for a few 30 secs or so.
            Anyway, I'll solder only some liquid elytes on the back side whether it will boot or not after baking. I don't have the nerves to solder it in the holes because of all the copper on PCB and hard solder used just to discover card is dead and I have to remove good caps again
            • double_DD
              How can I be sure that my EC chip is dead?
              by double_DD
              As the title suggests, how can I be sure that my EC chip is really dead?
              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
              03-12-2025, 07:47 AM
            • chth96
              Should I replace polymer capacitor?
              by chth96
              a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
              I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
              Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
              Is this ESR value of polymer capacitor correct?...
              11-18-2022, 04:22 AM
            • disorder
              ps5 edm-033 dead after hdmi/usb ports destroyed
              by disorder
              hello guys,
              i need help to repair a edm-033 ps2
              history : as always hdmi port and usb ports destroyed after unplugged
              after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
              so i changed it
              now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
              but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
              i don't see any projection of liquid metal on pcb.
              01-14-2025, 12:48 PM
            • zunasthegreat
              Chieftec GPS-450-AA with dead 20N60C3
              by zunasthegreat
              Hello everyone hope all doing well!
              I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
              09-01-2024, 07:12 PM
            • Beton
              Finding a dead short component
              by Beton
              Hi guys!
              I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
              So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
              I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
              I have a bench PSU and if I try to inject voltage the voltage...
              12-10-2021, 01:05 PM
