Need to replace a cap but the ones i have are slightly higher/lower in capacitance.
  • Cory_S.
    • Jan 2011
    • 11
    I need to replace a bad capacitor in a dell optiplex gx270.
    I decided to sit down and play some gmod last night and it completely locks up on me after woke it from sleep then opened my computer.When I restart theres no display and no beep from the bios.
    After I troubleshooting for a minute or two I finally think to check the caps and sure enough I find a bad cap by the agp slot.I checked them a few months ago when i heard about them being over filled and there was no sign of problems with them.
    Anyway,i`m curious as to whether or not i could replace the 3.6v 1500uf with either a 3.6v 1000uf or 1800uf,which are the only ones i have right now.It would be nice if i could so I dont have to order one from radio shack but at the same time I like to do things right and I dont want to have to worry about it putting too much stress on the motherboard or something and having it crap out in another 6 months.
    I've got to get it running again,this old hp/ubuntu combo isn't cutting it.
  • Spitz
    • Oct 2010
    • 95
    Re: Need to replace a cap but the ones i have are slightly higher/lower in capacitanc
    Originally posted by Cory_S.
    I need to replace a bad capacitor in a dell optiplex gx270.Anyway,i`m curious as to whether or not i could replace the 3.6v 1500uf with either a 3.6v 1000uf or 1800uf,which are the only ones i have right now.It would be nice if i could so I dont have to order one from radio shack but at the same time I like to do things right and I dont want to have to worry about it putting too much stress on the motherboard or something and having it crap out in another 6 months.
    The 1800uf one should work. By the way those are 6.3v caps.
    • eppidrummer
      • Jan 2011
      • 65
      Our company has just began recapping boards and we have over 200 gx270 and gx280's in stock. Most with bad caps.
      The caps that run along side the heatsink on those boards are normally always bad so I would at least change those also while your in there.
      -Eppidrummer
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        And don't buy from radio shack.
        A working TV? How boring!
        • Cory_S.
          • Jan 2011
          • 11
          @Spitz,yeah that was a typo.It was late and was tired.
          Im thinking ill just see what i cant find on the store instead.The prices seem pretty reasonable and i would feel better about it if i had the exact same one.Also money is pretty tight and the shack is likely going to be over priced judging from my experience with them.
          @Eppidrummer,thanks for the heads up.
          Oh,about the grounding strap,ive never used one(i know,im terrible),ive just always been careful and until now ive never had to replace components on something as delicate as a pc mobo.Say my soldering iron has a third ground plug,wouldnt a ground strap still be necessary and if so,would i want to attach a wire to the shaft of the iron then gator clip to to say one of the mobo mounting holes?I know,a bit amateurish to ask but at least i realize the importance of it.
          • retiredcaps
            • Apr 2010
            • 9271
            Radio Shack tends to sell only general purpose caps. Applications like power supplies require low ESR caps. Radio Shack doesn't stock them. Thus the "don't buy" from Radio Shack comments that you see.
            The same goes for a lot of big chains that only carry general purpose caps.
            --- begin sig file ---
            --- end sig file ---
            • Cory_S.
              • Jan 2011
              • 11
              Yeah see I wouldnt have caught that,my technical knowledge about electronics components is somewhat basic.Now is a good time to learn I suppose,thats why I came here.I would have read the part in the FAQ about different types of capacitors had it not been so late last night.
              Thanks for making that clear.
              • Hylax
                Replacement capacitor options please?
                by Hylax
                Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
                08-09-2024, 11:25 PM
              • mikkele86
                Luxman R-5045 - Capacitor at amplifier output broke, can i replace with higher capacitance ?
                by mikkele86
                Hello Im renovation a Luxman R-5045
                On the attached picture there is a cap 0.047uF (47nF) and a resistor, 10ohm. What is their purpose ? and what would happend if I were to replace the caps with lets say, 10nF or 100nF ?
                because thats what i got in stock :/
                04-16-2024, 12:37 PM
              • Ken123
                Replace memory module with lower density
                by Ken123
                Hello. Im playing with the idea of using a Samsung K4ZAF325BM hc14 to replace a faulty hc16 on my rx 6800
                I have some hc14 on stock but no hc16 and want to get The graphicscard going until hc16 arrives.
                Is this possible?
                If it is do you loose 1gb or 8g vram in that case?
                08-15-2022, 08:06 AM
              • quickname
                Cyberpower 1500AVR UPS repair
                by quickname
                I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                I decided to verify that the batteries were...
                11-12-2023, 09:57 AM
              • reessi
                ACER BM320 Monitor - Horizonal Flickering Lines After a While
                by reessi
                The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                They are black on the right and gradually fade to nothing on the far left.
                They start either after 5 mins or up to 2 hours after so annoying for testing.
                They flicker continuously very fast! With a slight pause milli-second every second.
                Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                I tested each half by removing the first the left flex from...
                06-03-2025, 09:58 AM
