Re: What's the rule for Poly mods? (Half the capacitance?)
TWBOR is crap.
I agree FC are better than PM. [And FC are usually cheap.]
FR should be fine.
They often use over rated [on the voltage] caps to get better ESR or better Ripple ratings.
""In regards to ESR, the bigger the capacitor, the less the ESR?""
If they are an equivalent 'grade' then yes.
Like Rubycon ZL is 'spec equivalent' to Chemicon KZE.
A larger cap in either of those will have lower ESR and higher Ripple ratings than a smaller one. [Of either of those.]
- But:
A higher grade cap [like say Rubycon MCZ] will have better ESR and Ripple ratings even if the can is the same size.
I thought of a way to show it. Will take me a bit to work it up.
TWBOR is crap.
FR should be fine.
- But:
